    Jul 2008
    Oregon
    I have a 9600xt aiw. My remote control stopped working, I think it was because of a Microsoft update interfering with it. I updated the driver from 2.5 to 3.01, which fixed the remote but then the TV wouldn't work! Same thing with newer drivers. I am using the MMC 9.03 version, I have tried 9.08 without success. Has anyone else had this problem or have a fix?
    Sep 2003
    Northern California
    I think you may have to do a complete re-install of the ATI software.
    As I recollect, there was a particular inatallation order for the involved.
    I just found this in my notes...
    installing or upgrading ATI
    First set screen to generic 640X480 X 256color generic vga.
    in control center...uninstall anything ATI
    run ATI uninstaller...just to make sure
    if needed... install directX then...
    1) win media encoder wmencoder***
    2) drivers ***dao***
    3) dvd decoder ***CDWIZ***
    4) multimedia center ***mmc***
    OR.....you might just first try a System Restore back to before the Microsoft update.
    Good luck
    Losing one's sense of humor....
    is nothing to laugh at.
    Jul 2008
    Oregon
    thanks mike, I'll try that
