  1. Whats the best program to burn a Interactive DVD as its 2 folders VIDEO_TS and AUDIO_TS as I use nero to just burn a movie which is same thing but are DVD Interactive games different
  2. Member Cornucopia's Avatar
    There are 2 different levels of interactivity:
    1. "DVD-Video"-only games (that work correctly in settops), which use quite complex DVDauthoring programming code to include all those interactive options.2. Hybrid/enhanced DVD-Video/DVD-ROM interactivity which includes Games, Weblinks, etc. with the enhanced/interactive portion that only works correctly in a PC.
    • To do this, you must use Sonic eDVD
    Neither can be authored just with Nero, although both could be burned with Nero once the authoring was done.
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    AFAIK, there can't be a valid DVD Video disk with 2 VIDEO_TS folders (and 2 AUDIO_TS folders). If you have that - it's simply not a Video DVD no more.
    /Mats
  4. Member Cornucopia's Avatar
    mats.
    I read the OP as "2 folders (VIDEO_TS and AUDIO_TS)"; if so, that shouldn't be any problem
    Scott.
  5. yes there is just 1 folder as VIDEO_TS and 1 folder as AUDIO_TS
    Apr 2006
    Grenada
    nice post
    How's My English?
  7. https://forum.videohelp.com/viewtopic.php?t=320843
    can you not help then as you put nice post
  8. Member steveryan's Avatar
    Jan 2003
    Manchester
    The burning prog shouldn't really matter, it's the authoring of these things that is important. Anyway, use ImgBurn.
    He's a liar and a murderer, and I say that with all due respect.
