  1. Member geohei's Avatar
    May 2002
    Luxembourg
    Hi.
    I have the "InterVideo Video Decoder" installed. It decodes my MPEG-2 streams with some errors (last frame ist missing).
    Where can I see which decoder is used (WinXP)?
    I'd like to give https://www.videohelp.com/tools?tool=GPL_MPEG-1_2_Decoder a try. This one only extracts a file called "GplMpgDec.ax". Where shall I but this file in order to make it available to applications (= so that applications use this decoder instead of the InterVideo)?
    Thanks.
  2. Member geohei's Avatar
    May 2002
    Luxembourg
    Nobody knows this, or is the question not clear (shall I rephrase)?
    Thanks,
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Doesn't the MSI install the decoder?
    Yes it does. Just tried.
    /Mats
  4. Mod Neophyte redwudz's Avatar
    USA
    Try dropping a MPEG file into Gspot 2.60 and then use the 'Render' buttons at the bottom and it should tell you what the computer is using to decode the file.
  5. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Actually I was wondering about this as well. It seems I have more than one MPEG-2 decoder or decompressor or whatever you want to call it.
    I noticed that in a "shoot out" where I provided a TEST CLIP and attempted to convert it (from MPEG-2 to MPEG-2) that my output had ever-so-slightly different colors than that done by another person using the same TEST CLIP but his own computer. His perfectly matched the original wehreas mine was "off" a bit from the original.
    Got me to thinking that it might have to do with how the original MPEG-2 is decoded for the re-encode i.e., the MPEG-2 decoder or decompressor etc.
    Oh and I kept the colorspace exactly the same as I used AviSynth and HCenc so I never did a colorspace conversion.
    So I think this question is a good question!
    - John "FulciLives" Coleman
  6. Member FulciLives's Avatar
    May 2003
    I think I did this and this is how I realized I had different MPEG-2 decompressors but the question then becomes how do you force which one is the default one and which one is the "best" one to use.
    I'm at work now ... perhaps I'll do a GSpot screenshot later tonight.
  7. Free Flying Soul liquid217's Avatar
    Feb 2002
    You can adjust the merit of the filter. The merit determines which filter is used. If one filter is unable to render the stream, it goes to the next filter.
    You can adjust the merit via the registry or with this tool:
    http://www.softella.com/dsfm/index.en.htm
    If memory serves me, Intervideo purposely sets their filter to a higher merit. In the past, I have simply unregistered that filter, so that another filter could be used.
