Hello, I've been playing with my capture card and captured two short 1920/1080 clips.
They're both mpeg program streams.
When I open the first with Gspot, it tells me Directshow would play it with the Intervideo (Windvd)
that I have installed.
On the second file, gspot tells me that Directshow would use the mainconcept decoder. (which was installed
by Sony Vegas I think)
The windvd decoder has the higher merit. Both files seem to have the same attributes,
why is directshow choosing a different decoder for each ?
Actually, it was Gspot itself, and not DirectShow, that determinedwhy is directshow choosing a different decoder for each ?
how the respective playback graphs should be built.
Applications can be smart/stupid enough to choose which filters will be used
for audio&video decoding. Sometimes their "free will" will not produce good results
(or any results at all). Graphedit does not have to have the same choices as
Gspot, WMP 6.4, or Media Player Classic. -
Microsoft mpeg-2 decoder problem
By ivanpop in forum Software PlayingReplies: 10Last Post: 27th Feb 2009, 09:10 -
Combining PowerDVD 7's Audio Decoder and Microsot's MPEG-2 Video Decoder
By Dark Alpha in forum Software PlayingReplies: 4Last Post: 11th Sep 2008, 18:44 -
Which MPEG-2 Decoder to install in new XP SP2 PC.
By mattstan in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2008, 13:16 -
Rotel 7.1 MPEG Multichannel Decoder....any others?
By Disco Makberto in forum AudioReplies: 9Last Post: 30th Nov 2007, 05:23 -
default MPEG-2 decoder?
By iThinkYouBrokeIt in forum Software PlayingReplies: 6Last Post: 6th May 2007, 18:49
