Newbie questions like this must really annoy you guys, and I'm sorry for that, but I really need an idiot-proof step-by-step process guide to get a downloaded torrent onto a disc to play on my dvd player?
Which programs, what darned buttons to press, are they free, etc?
Thanks awfully, fellas...
Results 1 to 11 of 11
Try ConvertXToDVD or the freeware version DivxToDVD. You can't get much simpler and it should work on the vast majority of those files and do a decent job of conversion to DVD. The payware version is recommended and it isn't expensive.
You may run into some MP3 VBR audio or some strange video formats that it can't handle. A program like Gspot 2.60 will identify what codecs are needed and the components and specification of the files. If ConvertXToDVD can't handle them, then you may need to do a little more work and study first before converting.
There's no one be all and all process from start to finish due to the many different "flavours" that can be contained within torrents. If you have a movie file format such as AVI, MPEG or WMV then convertxtodvd is your one stop shop.
However, if you have a compression formation such as 50 or so RAR files, and/or disc images (BIN/CUE), then you need to either extract what is in those to then be able to convert to DVD, or alternatively just burn the images as they were intended (sometimes VCD or SVCD).
And then there's all sorts of conundrums like VBR MP3 audio, whether or not to join multiple files together first, Is the torrent high enough quality in the first place to spend the time converting to DVD, is it worth spending time on filtering to improve the video/audio, and no doubt many others. Some might say that it is just easier to buy the original DVD if available.
Needless to say, all the information you will ever need is here in the guides section to your left, and in the stickies in the relevant forums.If in doubt, Google it. -
Great advice, much appreciated guys- is Nero also any use for this?
I would suggest that you only use Nero for burning. IMHO there are far better softwares available for everything else. And even then some will suggest that IMGBurn / DVDDecrypter is better to burn with as well.
Cheers Jimm
Just downloaded the IMGBurn program, it doesn't seem to want to allow me to upload my downloaded torrents, to convert to playable dvd?
This is exactly the problem I was expecting!
Damned gadgets...
ImgBurn is for burning DVD Video files. That is all that it does.Originally Posted by aelfheah
You have to convert your AVI files (or whatever) to DVD Video format.
The flow goes like this:
1.) Determine the type of files you have by using GSpot (check video and audio properties)
2.) Demux the audio and convert to AC-3 format if something else (like MP3)
3.) Convert the video to MPEG-2 DVD spec video files
4.) Put it all together with a DVD Authoring program
5.) Burn to a DVD Video disc.
Exactly what programs you use are up to you ... many different choices are available.
If you would like to have us get you started then load one or more of your files into GSpot and post the results here.
Read this on how to do that ---> CLICK HERE
Get a Philips DVP 642 DVD player. It'll play DivX and raw MPEG files!
Yep. The best advice, so far.Originally Posted by RayH
No need to read guides and manuals on conversions.
downloaded torrent avi video ENLARGES with dvd authoring??
By jbitakis in forum Authoring (DVD)Replies: 34Last Post: 22nd Dec 2011, 13:29 -
unfinished torrent
By pensioner in forum Video ConversionReplies: 4Last Post: 27th Oct 2009, 06:20 -
Creating a playable DVD
By DennyL in forum Newbie / General discussionsReplies: 3Last Post: 28th Jun 2009, 23:49 -
Downloaded torrent video-best software to burn to dvd
By jbitakis in forum Video ConversionReplies: 1Last Post: 26th Dec 2008, 17:26 -
Torrent searching engines and torrent softwares
By 1234567 in forum Off topicReplies: 7Last Post: 11th Sep 2008, 04:54
