Morning,i have an unfinished movie torrent stopped at 99%
i can however play it in windows media player all the way through with no problems.
I would line to convert ideally to an avi file to use on my ps3.
Any suggestions please for a simple way..thank you.
Pensioner
BitComet Unfinished Download File (.bc!)
Thats all it says,but will follow your advice..thank you. -
rename the file to .avi instead of .bc! after stopping it from downloading at bit comet.If you try to rename it without first stopping it ,the rename is gonna get rejected.It should work with PS3. Is their a small file in that download that you didn't select to be downloaded? Like a small read me or doc file? That could be the reason you're only showing 99%. But also follow Baldrick suggestion and "repair" it.After you rename it it might not play at all if it is corrupted or missing data...good luck.
Unfinished torrent files
By dexter30 in forum Newbie / General discussionsReplies: 15Last Post: 26th Jun 2010, 20:29 -
Unfinished threads in movies - random questions of unanswered movie ?s
By yoda313 in forum Off topicReplies: 30Last Post: 16th Nov 2009, 23:19 -
moving unfinished video project to new computer
By CAH1 in forum MacReplies: 3Last Post: 21st May 2009, 09:32 -
unfinished videos
By alintatoc in forum Newbie / General discussionsReplies: 2Last Post: 13th Mar 2009, 14:44 -
Torrent searching engines and torrent softwares
By 1234567 in forum Off topicReplies: 7Last Post: 11th Sep 2008, 04:54
