I've been looking for DVD to WMV software that produces perfect, or near perfect DVD quality rips. So far, I've tried a few different programs, and after about 5 hours of ripping I end up with grainy picture and sometimes out of synch sound...
So, does anybody know of a good DVD to WMV program? Any help would be appreciated!
encode the audio seperately do all the same things you would do w/ an avi w/ the exception of encoding as avi.. if you've messed around any w/ 3GP Converter it has the ability to take an avisyth script and convert it out to a wmv so just use the same basis for it.
Kind of in the same boat. Have DVD that I need to ultimately get as an .AVI (needing to edit). Can't be xvid or divx...need the uncompressed avi. The very end result after editing is going on web - either with WME as WMV or in Flash. I would take the VOB straight into Vdub mpeg and save out as AVI but due to the ac3, it's way out of sync and messed up.Originally Posted by jimmalenko
jimmalenko, is what your describing the best method for getting the uncompressed avi? -
Technically No, because DV-AVI is not uncompressed AVI - it's compressed 5:1 IIRC. However, there would be nothing stopping you saving to uncompressed instead of DV-AVI when using virtualdub. I am yet to find a circumstance where the DV-AVI was not "good enough" and I needed uncompressed (or losslessy compressed).Originally Posted by illini19If in doubt, Google it.
Try 123 DVD Converter it's a great program - just remember to change the few settingsOriginally Posted by Space
Can't play homemade DVD copies on player
By poz3614 in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2010, 07:26 -
Region Free DVD-R Copies
By Live2WinForever in forum DVD RippingReplies: 7Last Post: 22nd Mar 2010, 15:18 -
LG LHB953 not playing burned copies of my DVD's
By SMaldo in forum DVD RippingReplies: 8Last Post: 3rd Jan 2010, 22:43 -
Organising DVD copies on external HD?
By terrypin in forum Newbie / General discussionsReplies: 5Last Post: 1st Feb 2009, 09:43 -
DVD copies
By JimboS in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 23:33
