After buying a 1 TB external HD I'm about to copy my DVDs onto it. Mainly as backup but also with the idea that I can then quickly access clips for re-use when making new DVDs. I suppose a third use might be to play them directly from HD occasionally, although I'd normally plump for taking the DVD downstairs to my widescreen TV. Or take a couple of steps away from the PC to get the DVD disc original.
What do others do in similar situations please? First thought is to just copy the AUDIO_TS and VIDEO_TS folders into newly created folders with appropriate names ('2003 Holidays' etc)? One downside with that is that any multiple tracks/chapters are not identified, like 'Spain 2003' etc. (BTW, are there any utilities that will scan a VIDEO_TS folder and make a simple text file showing all the contents?)
Anyway, given that the IFO/BUP/VOB structure is therefore not a priority, I'm favouring the idea of copying only the individual VOBs, renaming them and changing the extension to MPG. Would that make sense? And if so, is there a utility that will do it automatically, renaming the VOBs to match their track/chapter labels? Or at least prompt me for them?
Any advice would be much appreciated please.
Terry, East Grinstead, UK
It is if you want to play then as DVDs instead of mpegs with no chapter stops, menus, subtitles etc.Anyway, given that the IFO/BUP/VOB structure is therefore not a priority
And VOBs are just arbitrary divisions of a MPEG file, usually about 1GB. This may span different chapters, scenes. Changing the filename to .MPG, as mentioned, may lose all the chapter info, subs and alternate languages. A VOB is a lot more than just a MPEG file.
Assuming you want to keep menus, chapters, etc., intact, you would want the whole VIDEO_TS folder. Or if you just wanted simple playback with most any software player, extract the MPEGs to one large MPEG file with a program like VOB2MPG. -
A VOB is more than an MPEG, and renaming the file extension is a mistake.
Thanks redwudz, I'll experiment with that VOB2MPG approach.Originally Posted by redwudz
However, on many past occasions, if all I wanted - as in this case - was the main movies, not the menu, I've changed a single VOB (e.g. VTS_01_1.VOB) to MPG and never had any problem. Isn't all that other stuff in each BUP and/or IFO? Have I just been lucky, and there's something I'm missing here please?
Terry, East Grinstead, UK -
You've been lucky.
From 'WHAT IS' DVD to the upper left on this page. (Worthwhile reading. Scroll down a bit to see the DVD structure.) From that page: In other words, just about everything in a DVD is stuffed into the VOBs.. VOB = The VOB files contains the actual video,audio,subtitles and menus.
Can't play homemade DVD copies on player
By poz3614 in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2010, 07:26 -
Region Free DVD-R Copies
By Live2WinForever in forum DVD RippingReplies: 7Last Post: 22nd Mar 2010, 15:18 -
LG LHB953 not playing burned copies of my DVD's
By SMaldo in forum DVD RippingReplies: 8Last Post: 3rd Jan 2010, 22:43 -
dvd player +dvix+usb with external 160GB external HD problem...
By spidermen in forum Newbie / General discussionsReplies: 14Last Post: 14th Oct 2008, 20:45 -
DVD copies
By JimboS in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 23:33
