I have a Pioneer 102D single layer DVD burner and unfortunately I can no longer find decent 4X media readily available for it. It burns and reads flawlessly so I hate to get rid of it. Speed is not an issue for me. I've been out of the tech loop for awhile so is there a decent basic bang for the buck burner out there. I was looking at the Samsung 18X with lightscribe at newegg and the NEC 3550. The nec seems to have a lot of bad reviews at newegg. I primarily backup a lot of movies for personal uses and an occasional xbox game for my son. Can you suggest a replacement for my Pioneer?
Results 1 to 10 of 10
I have that Samsung, it doesn't have buffer underrun protection, so dont be fooled cause its so cheap.
at rima.com they should have plenty of TY 4x media for sale. (?) -
Maybe I'm missing something here, but couldn't he just get 8x or 16x media and burn it at 4x? Will his drive not recognize the media?
You have a good question there smitbret. I wasn't aware you could use faster media for an older slower drive. This is my first and only DVD drive. I may have wrongly been under the impression they had to be speed compatible. If that is the case then problem solved! I don't need a new burner. This burner burns and reads most anything and RARELY has a coaster with what's left of my Ritek G04's.
I'll check out those other sources for media you guys suggested.
To the guy who suggested new firmware I already have the latest. There has been no newer versions since my last update.
Thank you all for your input.
If your firmware is up to date, you shouldn't have any problems using faster media, it will just burn at the fastest speed your burner can manage. Or at least you won't have any problems with media that was current at the time of the release of the latest firmware. If Pioneer stopped releasing updated firmware for your drive a couple of years ago, then it may not recognise media introduced since then.
Burner can only burn to Verbatim Media, but not anymore...
By iownju in forum MediaReplies: 6Last Post: 19th May 2010, 05:53 -
Windows Media Player Won't Play DVDs Anymore
By Card Shark in forum Newbie / General discussionsReplies: 3Last Post: 14th Feb 2010, 18:04 -
Is it easier on the burner to use R or RW media?
By PuzZLeR in forum DVD & Blu-ray RecordersReplies: 25Last Post: 28th Nov 2008, 11:40 -
DVD burner doesn't write anymore
By mr-scarface in forum DVD & Blu-ray WritersReplies: 7Last Post: 4th Aug 2007, 22:18 -
After a new burner and media.
By SE14man in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2007, 10:03
