From my understanding, the DVD burner on the Pioneer DVR-53x/63x must be repaired either by replacing the laser assembly from a compatible Pioneer drive or by removing the board containing the ROM chip and installing into a compatible Pioneer drive.
From the HD replacement thread, I have gathered that the only confirmed compatible DVD burner is the DVR-107 which is a close match to the DVR-107XA contained in the DVR-53x/63x.
In addition to either replacing the Laser assembly in the DVR-107XA or removing the ROM circuit from the original DVR-107XA and installing into a DVR-107, the additonal steps of reactivating the ID Number is required, which requires the Pioneer Data Disc and Service Remote as described in this thread: https://forum.videohelp.com/viewtopic.php?t=253998
I'm working on aquiring my third Pioneer DVR-531-H and know that the life of the DVD Drive is around 5000 hrs.
I will be adding more informatoin as I find it. Any insight/corrections/pictures/experiment results would be appreciated.
cheers
Results 1 to 1 of 1
United States (region 1)
How to replace new DVD burner and HDD for pioneer DVR-550H?
By voa in forum DVD & Blu-ray RecordersReplies: 5Last Post: 20th Mar 2012, 08:35 -
My Pioneer DVR-531H-s has developed burning problems ... replace burner?
By FulciLives in forum DVD & Blu-ray RecordersReplies: 86Last Post: 9th Dec 2009, 17:09 -
Need to replace burner in Pioneer 220s
By Brent G. in forum MacReplies: 6Last Post: 12th Nov 2008, 16:33 -
Pioneer DVR-543HS , is my DVD burner toast?
By stew182 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th Sep 2008, 12:57 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 07:20
