ok so its my first post
i have a few tv episodes on my pc as my hd is small i want to burn them ,the problem im having is putting multible episodes on one dvd, the files are in avi and i have the software to convert them to dvd.
so help needed please
Results 1 to 23 of 23
What software are you presently using? If you want a easy conversion, look at ConvertXToDVD. For freeware, the older DivxToDVD is still available.
If you want more control over your final product, for quality, you would need to study our guides. Episodic DVDs are easy enough to create, even with freeware programs. If you look to the left you will see the guides for the procedures to create a DVD. CAPTURE>CONVERT>AUTHOR. If you already have the video, skip the first one. Burning to DVD is the easy part. For a episodic DVD, look to our 'AUTHOR' guides and you should see several methods to produce that type of DVD.
First, you need to encode the files to DVD compliant video. For DVD specs, see 'WHAT IS' DVD. Then you need to author it to the DVD format. For freeware, DVD Authorgui or GUI for dvdauthor will work fine. If you have some money to spare, TMPGEnc DVD Author is very easy to use and fairly inexpensive. Also TMPGEnc encoder is good for conversion to MPEG-2 DVD format. Both have trial versions and are a good place to start.
And welcome to our forums. -
Why convert? Just burn them as data files. You can fit a lot more episodes per disc that way.
Get a cheap DivX player and you can even watch them on your TV. This is just an example and not meant as a recommendation:
http://tinyurl.com/tgfx4 -
ive just burned 4 episodes on one dvd as a data dvd, but its jumpin all the way through, so whats the best way to burn avi's straight to dvd?
ImgBurn is good. Check the AVI files first to see if they have packed bitstream, use MPEG4Modifier for this. If they have PB, simply unpack them using MPEG4Modifier.
He's a liar and a murderer, and I say that with all due respect. -
im looking to put avi files onto dvd with a menu, i dont want to convert them to dvd, is this possible
In a word - no.
ive been unpacking my files with MPEG4Modifier , but when i burn them to a disc the sounds out. any help
Have you decided to convert to DVD or not?
no i decided to burn them as files but the sounds out , not on the pc but on the disc
Just out of interest why did you totally ignore my advice about using ImgBurn? I'm not having a go at you but it's pretty galling for me when I give you advice and you just ignore it! Please try burning the files with ImgBurn.
The only reason I suggest using ImgBurn over ashampoo is that i've never used ashampoo, for all I know it's very good software. It's just I use ImgBurn a lot and I KNOW it's good software and doesn't change the data in any way.
You cannot just burn "avi" to dvd and expect flawless play ... you must check them out first .
A pc will play anything provided the correct decoders are installed .
Top set players WILL NOT ...
Use gspot to find out what they contain in video and audio ... most players are fine with xvid and mp3 audio ... I dont know how the players handle different "frames per second" though ... this could be an issue ...
I use super to do the fps conversion , and to xvid with mp3 audio , then burn as data .
Though I pass the video through vdub for rescaling and boxing , so all video is same scale ... make's it simple to join them later if required .
Ashampoo dose quite well , though I am a fan of imgburn , and nero .
My player supports folder navigation , so each gose into a seperate folder and is burnt as data .
Making a LP DVD
By zarnic in forum Authoring (DVD)Replies: 13Last Post: 11th May 2011, 07:47 -
making DVD
By narcissus in forum Authoring (DVD)Replies: 8Last Post: 19th Jul 2008, 00:18 -
making DVD
By narcissus in forum Authoring (VCD/SVCD)Replies: 2Last Post: 14th Jul 2008, 19:22 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
Making a DVD
By Lord Balthazar in forum Newbie / General discussionsReplies: 5Last Post: 29th Oct 2007, 08:10
