Got myself a hard disk drive camcorder, and I've uploaded the videos to my PC. I recorded two of my son's football games, so there's a lot of stop/start footage.
The problem is the two programs I have (ImageMixer from Sony and CyberLink's PowerDirector/Producer) simply lay out all the separate football plays as individual chapters. So I'm stuck with 12 pages with six clips each.
I hope I'm using the right terminology here. I'd like to have two titles on the DVD, one for each game. Within the titles, I'd ideally like to have all the footage as one "file". In other words, there's only two things to push: either Game A or Game B. If you push the Game A button, you then start watching the entire game as ~30 clips are strung together (a single file would be better, but individual chapters here are fine). Same with Game B.
There's got to be a better way to organize the videos, no?
Thanks.
HDD camcorders are worse than DVD based camcorders, and this is one of the many reasons why.
What you need to do is edit the material into the two movies that you want. I don't know the two software packages you refer to, so I can't help you with details on how. I suspect Power Director is probably the one to look at for this.
I would edit movie A first, get it the way I wanted it, then output it as a single video using as little compression as possible. Once that was done, edit movie B. After I was happy with the two of them, encode them to mpeg2 with DVD compliant specs, and author the disc with the menus required. This is probably where Power Producer comes in.
Sorry if this sounds a bit vague.Read my blog here.
It appears that your editor is taking the footage and creating a virtual click per each cut ( stop and go ) on your video. There might a preferance you can shoose to avoid doing that and simply capture and present you with one single clip which you can then cut, trim, reassamble to your heart's content. I think the program you are using is targeted at the rank ammateur and so it is trying to make as " idiot proof " as possible. Since you are definitely not in that category I would reccomend somthing a bit more proffessional. Give Vegas 7 of earlier versions a try. There is not much you cannot accomplish with Vegas so give the trial a try and see what you think.
No DVD can withstand the power of DVDShrink along with AnyDVD!
Organizing project folders
By weskennison in forum Newbie / General discussionsReplies: 3Last Post: 7th Sep 2011, 16:29 -
REALLY Organizing those Giant Black Hole Hard Drives
By ahhaa in forum ComputerReplies: 6Last Post: 4th Dec 2010, 10:27 -
Workflow! Files, organizing, formats, editing
By Jay_Z in forum EditingReplies: 0Last Post: 11th Jan 2010, 20:37 -
DVD Organizing Software
By acid_burn in forum ComputerReplies: 9Last Post: 16th Mar 2008, 02:07 -
Organizing and labeling miniDV tapes.
By vid83 in forum Newbie / General discussionsReplies: 5Last Post: 11th Dec 2007, 15:40
