I have 11 home videos on miniDV tapes. I have organized the tapes by date.
So far I temporary labled the tapes with "1", "2", . . ., "11". I'm thinking of naming them "0001", "0002", and so on.
How do you label your tapes? Should I add more info. to the tape name than just "0001", "0002", etc.?
I don't want to label any specific events as part of the tape name because there are many types of events on the same tape. Once I get my tapes labeled, I am going to creat a table in Microsoft Word with the tape name, time code, tape content, etc.
	Because whatever you create in Word will not store easily with the tape, I use small PostIt's (sometimes more than one) with brief content description and time and stick them inside the tape case.
 My tape labels are very general and I make them match the case insert label.
	The date often has more meaning than generic numbers. Especially for content you don't view often. Google is your Friend
	I can't use date because there are various dates on my tapes. For example, one of my tapes has dates ranging from April 2007 to September 2007 with various events.
 I was going to use "0001", "0002", and so on but just thought I would check to see how other people label/name their tapes before naming mine.
 Also, using Word will not be a problem for me because the only thing I have to do is look at my tape name and then look it up on the table. I will probably have a printed copy and a copy on my hard-drive.
	If I have a tape with multiple events on it I'll try to write as much as possible on the insert. I have some tapes with multiple baptisms from my church and I'll write "MBBC Baptisms" and put the dates. Usually if I film a sermon I'll put our church name, date, and sermon title. Then the tape itself I'll use the small label with name and date. For videos of my son I'll use a tape until it's full and put his name and the ages, like "Matthew Birth to 6 weeks" is the first. I try to make it fairly clear what's on each tape. My goal is that if something ever happened to me my family could look through the tapes and have a decent idea what's on them.
	I have 100's of DV, D8, Hi8 and 8mm tapes. The only way I can keep them straight is with an Excel database.
 The fields I have for each clip are
 Tape ID #
 Tape manufacturer (e.g. Sony, TDK ...)
 Time Code (clip start)
 Clip description
 Clip date
 Sort code 1 (e.g. travel, TV dub, project, etc.)
 Sort code 2 (e.g. archive, erase, dub, blank, etc.)
 CommentsRecommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
  capturing minidv tapesBy zoranb in forum MacReplies: 62Last Post: 9th Feb 2014, 06:07
  Convert all MiniDV tapes to computer and say good bye to those tapesBy iho in forum Video ConversionReplies: 38Last Post: 17th Dec 2013, 01:01
  I need to transfer my miniDV and old hi8 tapes tapes to dvdBy bryanport in forum DVD & Blu-ray RecordersReplies: 9Last Post: 21st Dec 2012, 20:53
  Reusing miniDV tapesBy yurkyurk in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 27th Oct 2008, 16:06
  copy miniDV tapesBy circc in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 24th Feb 2008, 20:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
