I fequently make mix CD's of songs for my car, my workshop, etc. Sometimes I make multiple copies and share them with friends. I sometimes like to put some funny or appropriate movie dialogue in the beginning, middle or end of the cd. Is there a way I can sample the audio from a DVD directly into my Mac, via an audio tool like Peak without having to run an audio out from a dvd player to the audio in of my Mac?
Not sure about the best way, but here's how I would do it.
Suppose I'd want a few lines audio from a DVD, located on Title 1, Chapter 19. Knowing that, I won't have to rip the whole DVD, but just that one chapter. I would use MPEG Streamclip to make a rough selection and demux to aiff. In Amadeus, or any audio editing app with visual soundwaves, I could make an exact selection. Then I could add that final sound file to my Audio CD compilation. -
You could try Audio Hijack.
http://rogueamoeba.com/audiohijack/ -
Second Audio Hijack (pro).
No ripping needed, creates the
mp3 on the fly.
Before someone else chimes in, there is also Wiretap.
;-p"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Cool, thanks for the help. I will try that out this weekend and see how it goes.
ditto Audio Hijack. the free downloadable version will allow up to 10 minutes of ripping audio; quality gradually degrades (noise is added) thereafter (of course, the Pro version will remove all that). good luck.
Cinematize does very well in extracting the audio only on a chapter by chapter basis. It will automatically make individual AIFF files for each chapter on a video DVD.
Is a 44.1 KHz audio capture OK for a compliant DVD?
By c627627 in forum Capturing and VCRReplies: 8Last Post: 23rd Mar 2010, 05:29 -
Any chance for a spell check modification or code snippet?
By G)-(OST in forum FeedbackReplies: 22Last Post: 7th Jun 2009, 01:41 -
Help with VHS -> DVD using capture card (audio problem)
By dustin1 in forum Newbie / General discussionsReplies: 20Last Post: 8th Feb 2008, 00:27 -
capture audio from dvd
By destinysolo in forum AudioReplies: 2Last Post: 9th Oct 2007, 20:35 -
How to - Capture DVD 5.1 Audio - Coaxial vs. RCA Audio
By JBredensteiner in forum Capturing and VCRReplies: 3Last Post: 13th Jul 2007, 13:46
