I have my DVP5960 conected to an external HD (300MB Maxtor, 1200rpm. Acomdata encloser), everything is working fine so far. I have a lot of files on this disk already.
I'am trying to find out what kind of sorting does the DVP5960 use to display files list?
żany clue?
The 5960 obviously does not sort alfabetically. After having performed several tests it seems to me that the 5960 lists the files in the order they have been put on the disk.
So .. if you number your files or directories sequentially and keep a list of the numbers and the corresponding names you may be able to find your files back (even blind)
Yeah, I know, it sucks, but it works for me.
QubyB
Philips DVP5960 and USB
By lets in forum DVD & Blu-ray PlayersReplies: 715Last Post: 10th Jun 2012, 10:03 -
.mkv on Philips DVP5960?
By Conrad007 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Dec 2009, 11:11 -
philips dvp5960
By tonie in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Sep 2008, 14:58 -
Philips DVP5960 or 5982?
By siskiou in forum DVD & Blu-ray PlayersReplies: 11Last Post: 20th Apr 2008, 21:28 -
Philips DVP5960 Help
By clubfoot in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Sep 2007, 05:39
