    Sep 2007
    Hi Guys,
    First post!
    I have a Philips DVP5960 DVD player and I have recently purchased a Toshiba PX1223E-1G32 320GB 3.5" External USB Hard Drive.
    I did a quick format to FAT32 using swissknife. I then transferred an .avi on to the drive and everything appeared ok within explorer, just the avi and the sytem information folder. I then plugged in to the dvd players usb port, powered up the drive before swithching on the player and what i got onscreen was about 50 folders named &^_-$RR_ and all sorts of other random nonsense.
    I then plugged the drive back into my PC to discover that these files take up 298GB of the 300GB i have available.
    Am i doing the format correctly, it only took 10 seconds max?
    Or do I need to format in another way?
    Thanks In advance
    Rob
    Sep 2007
    Ahhh Ive just sorted out my problem.
    I used a prog called fat32format.
    All is now good and can use the usb drive through my dvd player
    Mods feel free to delete my topic
