What is the difference between the two players?
I can get the 5960 locally (easier to return if there are problems right out of the box).
Would have to order the 5982 online.
Price is pretty much the same.
Were there problems with the 5960 that are fixed in the other model?
Results 1 to 12 of 12
The main difference is the addition of 1080p output on the 5982. From what I've read the 5960 is less problematic and you can find hacked firmwares to add support for longer filenames (on DVD, not USB), packed bitstream, etc. The 5982 might be able to play slightly higher bitrates over USB. I have a 5960.
Ah, thanks!
Where would I look to find the appropriate hacked firmwares?
Any recs as to which one to use?
Would the 3960 be a better choice if I don't really need the USB?
My main reason for choosing a Philips player is price, and PAL/NTSC, since I have quite a few European dvds, multi-region hack, etc. -
The 5960 does a pretty good job of converting PAL to NTSC (I have several PAL discs too). I don't know much about the 3960.
Here's a site with lots of 5960 information:
http://www.phunkyfish.com/article/4/philips-dvp-596012 -
Thanks again!
I have actually looked at that site earlier, but there are so many different firmwares available that I have a hard time figuring out which one would be appropriate. -
Have mercy on an elderly, not tech savvy, lady!
I can follow simple instructions, and manage to find the right forums to ask questions, but that's where my expertise ends.
I won't complain if I don't like the results of the suggested firmware, I swear!
As of a half hour ago, I have the 5960 set up. Region Hack worked great. I'm playing a PAL dvd right now.
The current firmware on mine is 37.06.42.33. -
Congratulations on getting your 5960 up and running! I wouldn't bother upgrading the firmware unless you run into problems.
I used to use one of the firmware's hacked for longer filenames and multiple b-frame packed bitstream. The longer file names were nice -- except with MP3 files where the long filenames ended up spilling over into another field.
At some point I reverted to one of the official firmwares. I forget why -- maybe to see if packed bitstream was working in the official release. I haven't bothered to go back to the hacked version because I use my HTPC (hooked up to my HDTV) for most non-DVD viewing these days. -
The 3960 supports PAL to NTSC as well.Originally Posted by jagabo
I think all the Philips players do... And they all appear to have the same hack... As well as the same remote.
Frank Zappa: "People wouldn't know a good movie if it smacked 'em in the face." -
Thanks!
I've purchased a 5960 for now and am testing it with different dvds/cds.
So far I've tried .avi, PAL, NTSC and a bunch of stuff I burned off my old vhs collection.
No problems so far.
Have not tested the USB yet. -
What is the latest firmware on the phunkyfish web site? It's very convoluted and easier to install the firmware than to download it.
Thanks,
MJ -
I'm very happy with this player so far, but would like to try out some of the modified firmwares (for resume play function, and long filename for cd/dvd).
Problem is that the firmware on my player is 37.06.42.33, and the latest one posted on the philips website is 37.06.42.29.
I don't really want to try flashing without having a back-up of the current firmware on my player, but the only link I could find to one (rapidshare.de/files/38072466/bakup_philips_dvp5960.rar.html) seems to be broken.
Can anyone help?
Philips 5982/37..No upscalling above 480P
By siam123 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 26th Mar 2008, 15:08 -
Philips 5982 and USB
By chits007 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 26th Dec 2007, 09:43 -
philips 5982 with a better remote possible?
By wkk in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Sep 2007, 23:32 -
My DVDs play 2x on Philips 5982
By Gritz in forum Newbie / General discussionsReplies: 0Last Post: 21st Sep 2007, 21:57 -
Problems with Philips DVP-5982/37
By BellaDonna in forum DVD & Blu-ray PlayersReplies: 2Last Post: 29th Aug 2007, 21:26
