Hello, I am new here and I don't know of where else to ask this question.
It's been really driving me crazy on how you can put 20 episodes onto one disc (DVD-R)![]()
I have 20 episodes (downloaded) all compressed to around 175 MB
23 frames/second
137kbps
24 bit
video compression DivX YV12)
with the exception of one which is 338 MB (it was 7.99 GB)
( 15 frames/second
283kbps
video sample size- 24 bit
video compression divx)
I really would like to ask what programs I can use ( I have nero v. 6.1 (with the video dvd plug in I think) and Div-x converter, blaze media pro, bitlord, utorrent, limewire 4.8.1) To also create menues and backgrounds and background music. Also how to compress my files even more (if they won't fit already)
thank you all so much for taking the time to even read this.[/b]
Closed Thread
Results 1 to 9 of 9
sure..it won't look very good...but i guess that's not the point...137kbps is very low quality...barely watchable
well is it possible to help me out please. I really would like some help with this. Is nero good to use? What programs do I need to be able to fit all these onto a disc? Total they are 3.3 GB which is perfect to put on a dvd-r but it says that it exceeds the limit, I heard that there is a program that lets me convert them so that it can fit onto the dvd-r. Then I need to know what is the best way to make interactive menues with backgrounds and such. Thanks.
Need to burn TV episodes to DVD
By harishkumar09 in forum Authoring (DVD)Replies: 44Last Post: 3rd Mar 2013, 06:35 -
Put 4 Sopranos episodes from 2 DVD5 to 1 DVD9
By audax in forum Authoring (DVD)Replies: 2Last Post: 3rd Jan 2012, 02:23 -
DVD episodes to MPTS
By waveqam in forum Video ConversionReplies: 3Last Post: 15th Apr 2009, 17:37 -
Looking for guide: TV Episodes to DVD!
By munchgrunch in forum Video ConversionReplies: 3Last Post: 16th Jul 2008, 00:19 -
How do you author many episodes to 1 DVD-R?
By 1980sumthin in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2007, 23:49
[/b]
