...and if it does, why do you think that is? Click here
Results 1 to 18 of 18
It does look strange ... it almost seems SLOW MOTION at times ... but even then it isn't smooth as if it is SLOW MOTION but also has DROPPED/MISSING frames.
I can't tell you HOW it got that why without more details as to how you made it ... maybe if you could give some detailed steps as to the creation of the clip (how it was captured and encoding to WMV) then someone can help.
I've never fooled around with WMV myself though so I wouldn't have a clue
BTW I downloaded the clip and played it from the downloaded file and my computer is very fast (P4 3.2Ghz) so it's definately not a decoding problem due to a slow computer.
I transferred my original tapes (recorded in 1984) to DVD-RAM in XP mode. I then take that disc and run it through TDA to encode it to MPEG. I then do any editing in TMPGenc MPEG Editor. I then load my mpeg file into TMPGENC 3.0 to encode to .wmv. I then take that file and load it into Windows Media Maker to get it down to a reasonable size for viewing and downloading. I have another example here that does not exhibit this at all, same work flow. Weird because I've down this thousands of times. Thoughts?
Click here for another example that isn't choppy. -
If you step through your video frame by frame you'll see that often the same frame repeats several times in a row (for example, at about 14.5 seconds into the video as the camera zooms away from the bass). I suspect the DVD recorder is dropping frames because of a bad sync signal, and substituting the previous good frame as many times as necessary to keep A/V sync.
You can verify this by stepping through the orignal MPEG file from your DVD-RAM. If the problem is there then you know that's the source of your problem. -
2 choppy?
either it is or it isn't
I'm not dl'ing a 18mb file to see
probably too much re-encoding
you've got at least one extra step in there
I have over 100 wmv clips online...all as smooth as silk -
Originally Posted by zoobie
It isn't necessay to download, with WMP you can view directly from my site. I've got at least that many online and those didn't result in any problems as evidenced in the second clip I posted with the same workflow. There are a lot of steps. I don't see what I can eliminate though. Can you post your work flow?Here is another example that is fine.
How about putting your mpeg directly into that new SUPER for conversion to wmv?
How about saving your editing as avi and dragging it thru wmm?
I use DVD-RAM because I record musical performances (one song) off the air and post them on various forums on the internet; it's really easy to deal with, I don't have to finalize a whole DVD-R to rip one .mpg file from it. TMPGEnc DVD Author converts the .vro file into a .mpg file. I then load that file into TMPGEnc to convert. It is my understanding that no re-encoding has taken place up until it is converted to .wmv. I tried loading the .mpg file into WMM and it loads up, but when I try and save it to my computer I get the message below. I've been working with .wmv for a while because it is most compatible among the forums that I post in but after seeing the quality of Divx, I think those people are just going to have to download the player that stuff looks great. I'd post the clip in Divx but you said you didn't want to d/l it.
Oh, yes I do, it's a 250 gb drive with hardly anything on there!
Interesting...looks like it's close to working.
You'll just have to keep trying every which way until something works.
When I first started, I noticed my wmv's were now choppy. I would end up saving it in every config possible.
Then, I'd go back and see which one, if any, was smooth. I later found some settings off.
If it's a video site, they probably already have the capability of playing DivX & XviD -
So it IS about settings, that's what I thought. Thanks for your help. Can you tell me what you use and a few of the basic settings? TMPGEnc has a slider that moves from motion on one side and quality on the other, that cured about 90% of the problem. This really was the oddball, most of my other clips look fine. Nah, it's not a video site, they are artist forums or guitar/amp forums, etc. Hey, thanks again for your time.
Well, I have a different setup. I import DV, edit, then save as DV without re-encoding. This can be converted to whatever.
Keep goofin with it...You'll probably find some setting off somewhere. -
Thanks for taking the time out to help me. I think I'm going to go the Divx route. I just pasted the link below into WMP 10 and it fired right up, looks great to me and I think everybody that owns a PC has that on their computer. Check it out if you want; thanks again, man.
http://myfavoritevideoclips.com/robclips/robtoday.divx
How to fix choppy video
By dexter30 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2010, 07:52 -
choppy video on blip.tv
By gtmb in forum Video Streaming DownloadingReplies: 3Last Post: 25th Sep 2009, 09:46 -
After conversion video is choppy
By 2112Video in forum Authoring (DVD)Replies: 1Last Post: 26th Aug 2009, 09:57 -
VOB2MPG choppy video
By 123fish123 in forum Newbie / General discussionsReplies: 4Last Post: 20th Mar 2009, 12:06 -
choppy video playback
By RobotFood in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 07:40
