I used VOB2MPG for the first time based on some of your advice. I used the .IFO function to backup to an MPG file. It went through the process but the .mpg file it produced was very choppy...almost as if it was only capturing every 3rd frame or so. I checked the settings but the software doesn't seem to have many or anything that would explain this. Anyone ever encounter this?
Playback quality is dependent on your Mpeg2 decoding codec. What are you playing the mpeg with?
For example MPCHC has a good internal mpeg2 decoder. If you are using WMP it may be worth installing Dscaler MPEG Filters and boosting their merit.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
YEah that went a little over my head actually. I think maybe the easiest thing to do would be to go from DVD to AVI instead....thanks for the post.
Well install Dscaler MPEG Filters first. Reboot and then see if you get smooth playback.
VOB2MPG PRO - Video comes out pixelated
By freak6148 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 30th Jun 2011, 12:05 -
Video preview not working in VOB2MPG PRO new build 3.0.0700
By Joey9 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th May 2010, 15:44 -
MPEG2 files of VOB2MPG not accepted by ATI AVIVO video converter
By 33M344 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 13th May 2010, 14:53 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 01:53 -
Video noise on VOB2MPG Version 3?
By Reading Bug in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 19th Apr 2009, 05:21
