as my title say.quality does matter.i just wana know how to put a 6 hours movie with normal dvd player compatible format on a dvd..what application i need to use to do this??
Results 1 to 11 of 11
any good mpeg encoder like tmpgenc xpress, tmpgenc plus, hc, mainconcept mpeg encoder where you can set the bitrate manually or set the output size. i recommend using a low resolution 352x240/288. calculate the bitrate using a bitrate calculator.
then author and burn the mpeg to a dvd with any authoring tool like tda. -
sorry man.i just now forgot to mention that the format i wana convert is RM or RMVB real media format..and i know it can convert to dvd format but just dont know wheater it can convert to low birate than i can squeeze 6 hours movie on 1 dvd.
Think of a blank DVD as a piece of pastry. Now roll out that pastry into 3 fairly thick "logs". Thats your 3 hour film. The thickness is the quality. Now roll out that pastry into 6 skinny little logs . they look pathetic dont they.. not enough there to fill anybodys belly. Now thats your six hour film/series.
six hours of vcd footage will fit onto a dvd and it can look quite acceptable (like vhs) but not top quality like a commercial dvd.Corned beef is now made to a higher standard than at any time in history.
haha...vcd quality is ok on me.you know what..the dvd drama i bought (come from china) put 7 hours movie on a normal 4GB dvd..
All you really need is an encoder that lets you set any bitrate you want and a bitrate calculator.
http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm steps you through how to do it with TMPGEnc.If in doubt, Google it. -
It seems nobody asked if this is for SL or DL disc. If SL, then the average bitrate will have to be quite low (~1.6Mbps), but if it's DL, then it could be up to ~3.15Mbps. That is decent for 1/2D1 material.
Cyberlink Powerdirector makes movie in 8 hours ?
By ddinc in forum Authoring (Blu-ray)Replies: 4Last Post: 10th Mar 2012, 04:05 -
Need to put a bunch of movie scenes together
By neworldman in forum EditingReplies: 2Last Post: 1st Oct 2011, 22:55 -
How to put 640x480 video in 1280x720 frame in Sony Vegas Movie Studio?
By vid83 in forum EditingReplies: 6Last Post: 10th Feb 2011, 23:47 -
Help with Ripping audio from a VCD (2 discs) to put 1 DVD for a movie.
By shuya_nanahara in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2009, 23:40 -
Hours of Music without Hours of Video Data in DVD Architect
By Guff22 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2008, 22:23
