Can U guys pls Link me a Good Gordian Knot Guide having Having the Best Settings ??? i have not Found the "Right Settings" As yet For rippin ....
Pls let Me know on this...
also Pls Let me know on the filters to be used
thnx a ton...
There are many programs to do this job, GK is one, others you may give a try to avi.net and FairUse Wizard. I personally prefer avi.net as it gives me the results I want with very little tweaking and is lot faster than AutoGK.
If you talk in terms of settings, thats a very tough question asit depends on the type of movie and few individuals prefer final output size over the bitrate or frame size etc. So far, at least I failed to find how some individuals claim (on DivX forum) that they can fit 2 hour movie in 700mb file, using bitrate of about 1000kbps
So either go for AutoGK or Avi.net, everything is well set there!
Problem with Gordian Knot
By eliqush in forum Video ConversionReplies: 3Last Post: 7th Jul 2009, 19:35 -
What's the best filter to use in Gordian Knot?
By ltd. in forum Video ConversionReplies: 1Last Post: 5th Jan 2009, 13:22 -
using Gordian Knot
By ricmetal in forum Video ConversionReplies: 3Last Post: 6th Dec 2007, 14:20 -
Gordian Knot help
By zookeeper525 in forum DVD RippingReplies: 25Last Post: 16th Aug 2007, 00:49 -
Auto Gordian Knot anyone?
By Lee82 in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 20:31
