hi
when im coding a video using Gordian Knot
the job seems to be fine
just one problem is that i can't add credit text in the AviSynth Frameserver window.
when im marking - no comments and want to add credits it won't let me
why is that happening?
10x
screen capture attached
http://i31.tinypic.com/30uzkp1.jpg
I suspect this isn't a GKnot problem but an AviSynth problem. You're probably giving it a wrong script. You didn't say what the error message was when opening the script in VDub(Mod), you didn't show the edited script with your text, you gave virtually no details at all. So how is anyone supposed to know why it doesn't work?
If all you want to do is add some text to the script but without it also going into the video, make sure and add '#' at the beginning of each line, just as in the pic you showed. That 'comments out' the line, meaning that nothing happens. -
I did it
i added the # and also marked the No Comment line
and when im coding the video it seems to be ok
but when im playing it there is no sound -
Did you add in the sound when setting up the encode in the Encoder->Add section?
Check the AVI in GSpot or MediaInfo. They'll let you know if there's audio but you can't hear it. There's a chance you added in the audio but don't have the filter installed to play it. For example, if the audio is AC3, you might need the AC3 Filter.
Gordian Knot AUDIO PROBLEM: DTS to VBR MP3? (HD 720p.mkv to SD XviD.avi)
By Randm in forum Video ConversionReplies: 2Last Post: 31st Jul 2009, 01:49 -
Major problem loading audio from AVI file into Auto Gordian Knot v 2.45
By robo5050 in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2008, 06:12 -
Problem On Encoding DVD to H.264 By Gordian Knot
By bugsboney in forum Video ConversionReplies: 6Last Post: 27th Jul 2008, 09:52 -
using Gordian Knot
By ricmetal in forum Video ConversionReplies: 3Last Post: 6th Dec 2007, 14:20 -
Gordian knot sound problem !!
By markos in forum DVD RippingReplies: 3Last Post: 22nd Nov 2007, 03:58
