  1. Chris-
    Downloaded newest version, installed and registered OK, but menus and conversions (PAL .mpg to NTSC) are coming out watermarked. Log below:
    Removed very long log
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can you redownload it? For an hour there was the wrong version on the server but it was fixed. Apologies.
  3. No problem...wouldn't you know it would be the one hour when I thought to get the new version?
    Dwight
    - Herm Albright
  4. Chris-
    Keep getting an "invalid or corrupted" message for the .zip file.
    Dwight
    - Herm Albright
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Well. The zip is fine. Try clearing your browser cache.
  6. You were right, as always. Sorry for the hassle.
    Dwight
    - Herm Albright
  7. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    No. It was my fault...
