    Jul 2007
    Canada
    hi,
    i recorded a live stream which i was watching using WM Recorder...
    i hve the file now...i want to add watermars to tht video...the file is in .asf format..
    i tried adding watermarks using Watermark master software..but after the watermark is added..the sound is bad..theres some background disturbances coming...which werent there in original file
    i tried to convert the to .wmv so tht i coud add using Windows movie maker..but while importin its saying sme codec is missing...
    cannot do it in virtua dub as the file format is not supported...
    i dont wnt to convert to .asf to othr format beacause the size increases..the original file size is always small..
    so can u guys suggest me the best software out there which i could use to add watermarks to the video in .asf format without the quality nd voice being lost (witht voice disturbances occuring)
  2. Member zoobie's Avatar
    Feb 2005
    Florida
    you want to watermark someone else's video?
    Jul 2007
    Canada
    no, i recorded a streaming video using WMRecorder nd i wnt to watermark it..not someonelses video..
  4. Member buttzilla's Avatar
    Apr 2007
    Deep Space Nine
    Where did you record the streaming media from?
    Jul 2007
    Canada
    it was a streaming video of a cricket match.....i recorded it so tht i could share the highlights..so can smeone tell me the software
    Jul 2007
    Canada
    any help guys
