I've started doing some DVD conversions lately, beginning with SmartRipper and feeding the video through DVD2AVI and AVISynth before hitting Helix Producer or TMPGEnc, depending on the application. Do any of these programs have the capacity to add a watermark (whether native or via a plugin), or should I start looking for a different conversion software?
Apologies if it's in the wrong forum, and thanks in advance.
There is no native Avisynth Logo filter for Avisynth, but you can add logos with Avisynth. You can use the logo filter of VirtualDub as described in the Avisynth 1.0x example collection.
If you dont want to go this ancient way, you can use Avisynth 2.0x with the native Layer filter. To do this first you have to convert the image (or the imagesequence) to a videoclip. This could be done with the external plugin
ImageSequence. If you need some sample scripts let me know. -
Thanks for the plugin... looks like it might be what I need. Sample scripts would be great, if you have them.
Also, can you provide clarification as to the numbering system?("file%.3d.jpg", "file%d.jpg", and the like) -
These examples were created with Avisynth 2.51. Avisynth 2.52 will probably have a native ImageReader filter.
To demonstrate the logo overlay I have borrowed two animated gifs from http://www.gifanimations.com/
Since ImageSequence requires 24 or 32 bit images, I have converted them to 24bit BMP image sequences.
Video source is MPEG-2 (DVD2AVI 1.76 project) PAL 720x576.
First you have to copy Corona.dll and imglib.dll to the system directory.
The first example overlays the video with a simple still image.
Here is a simple animated logo.Code:# load the needed plugins LoadPlugin("F:\editors\Avisynth\plugins\2.5x\imagesequence\imagesequence.dll") LoadPlugin("F:\editors\Avisynth\plugins\2.5x\mpeg2dec\MPEG2DEC.dll") # open the videosource vid=Mpeg2Source("H:\lotr\part2.d2v").ConvertToRGB32 # open the still image img=ImageSequence("H:\pumpkin\pumpkin1.bmp").ConvertToRGB32 # mask the white background but leave the other colors unchanged img=ColorKeyMask(img,$FFFFFF,$000000) # place the image into the upper left corner of the video ovl=Layer(vid,img,"add",255,0,0) return ovl
Well, IMHO the only reason to add a logo is to add some fancy effects to your video.Code:# load the needed plugins LoadPlugin("F:\editors\Avisynth\plugins\2.5x\imagesequence\imagesequence.dll") LoadPlugin("F:\editors\Avisynth\plugins\2.5x\mpeg2dec\MPEG2DEC.dll") # open the videosource vid=Mpeg2Source("H:\lotr\part2.d2v").ConvertToRGB32 # open the imagesequence (2 images) img=ImageSequence("H:\pumpkin\pumpkin%d.bmp",1,2,25).ConvertToRGB32 # mask the white background but leave the other colors unchanged img=ColorKeyMask(img,$FFFFFF,$000000) # let the images sequence loop (almost) for ever img=Loop(img) # place the image into the upper left corner of the video ovl=Layer(vid,img,"add",255,0,0) return ovl
So have a look at the following simple example.
If you like, download pumpkin.bmp, baby_crawling.bmp and the ovl clip from the 3rd script here.Code:# load the needed plugins LoadPlugin("F:\editors\Avisynth\plugins\2.5x\imagesequence\imagesequence.dll") LoadPlugin("F:\editors\Avisynth\plugins\2.5x\mpeg2dec\MPEG2DEC.dll") # open the part of the videosource where you want to add the imagesequence vid1=Trim((Mpeg2Source("H:\lotr\part2.d2v").ConvertToRGB32),0,199) # open the rest of the video vid2=Trim((Mpeg2Source("H:\lotr\part2.d2v").ConvertToRGB32),200,0) # open the imagesequence (10 images) img=ImageSequence("H:\baby\Baby_crawling%.4d.bmp", 1, 10, 25).ConvertToRGB32 # mask the white background but leave the other colors unchanged img=ColorKeyMask(img,$FFFFFF,$000000) # let the images sequence loop (almost) for ever img=Loop(img) # moving anitated image (actually it is a videoclip now) over the first clip ovl=Animate(0,199,"Layer",vid1,img,"add",255,-150,250,vid1,img,"add",255,750,250) # merge both videoclips return ovl + vid2
If you want to load a single image, just write the real filename.Also, can you provide clarification as to the numbering system?("file%.3d.jpg", "file%d.jpg", and the like)
If you want to load an image sequence the frame number must be added to the filename like image1.bmp, image2.bmp etc.
This is the standard numbering, so write image%d.bmp.
In the 3rd script I have used Baby_crawling0001.bmp - Baby_crawling0010.bmp, a 4 digits numbering, so the proper syntax is Baby_crawling%.4d.bmp -
Okay, it makes sense, but I'm having trouble with it. Here's the script I'm using:
Firstly, I'm forced to use "CoronaSequence", because the "ImageSequence" directive responds with a "NO PICTURES FOUND" error.Code:#Load the necessary plugins LoadPlugin("mpeg2dec.dll") LoadPlugin("imagesequence.dll") #Load variables with logo and video clips logo=CoronaSequence("v:\logo.bmp",1,150).ConvertToRGB32 audio=WAVSource("source.wav") videoraw=MPEG2Source("source.d2v").ConvertToRGB32 #Chop video into three sections video1=trim(videoraw,0,300) video2=trim(videoraw,301,450) video3=trim(videoraw,451,0) #Prepare logo with mask and fade logo=ColorKeyMask(logo,$FFFF80,$000080) logo=fadeio(logo,10) #Add logo to second part of video clip video2=layer(video2,logo,"add",255,640,400) #Reassemble video, add audio, and shrink video=video1+video2+video3 audiodub(videoraw,audio) BicubicResize(360,240)
Secondly, the audio comes in at the right time, but gets ahead of the video stream within 15 seconds. Removing the Image plugin and the logo references doesn't fix it, but removing the ".ConvertToRGB32" tag from the videoraw declaration puts things right back on track. Any ideas? -
First of all your script worked quite fine here. Of course I have replaced your source with my own ones and I have changed videoraw to video in line 19, that probably was a typo only.
This does not make sense for me. Let me try to explain...but removing the ".ConvertToRGB32" tag from the videoraw declaration puts things right back on track.
Line5: The logo clip must be RGB32, because ColorKeyMask requires RGB32 input.
Line7: Mpeg2source returns a YUY2 clip if you remove ConvertToRGB32, namely videoraw.
Line10: So video2 is a YUY2 clip too.
Line16: Layer can overlay two clips of different sizes but with the same color format.
Since logo is a RGB32 clip, video2 must be RGB32 as well. So either video2 or videoraw
must be converted to RGB32 before.
But I believe, I have found a solution.
Your video could get out of sync due to a wrong specified framerate. ImageSequence and CoronaSequence return a 25 fps clip by default.
Layer takes the framerate of the base clip while the audio is unchanged at that point.
So I think, you have to set the framerate in line 5. But the filetype of fps is integer, not float.
If your base clip is NTSC 29.97 fps and the logo shall appear only a couple of seconds, you may not notice the slight audio delay, otherwise you have to convert the logo clip to the proper framerate.
Code:LoadPlugin("mpeg2dec.dll") LoadPlugin("imagesequence.dll") audio=WAVSource("source.wav") videoraw=MPEG2Source("source.d2v").ConvertToRGB logo=CoronaSequence("v:\logo.bmp",1,150,30).ConvertToRGB32 #logo=ChangeFPS(logo,videoraw.framerate) video1=trim(videoraw,0,300) video2=trim(videoraw,301,450) video3=trim(videoraw,451,0) logo=ColorKeyMask(logo,$FFFF80,$000080) logo=fadeio(logo,10) video2=layer(video2,logo,"add",255,640,400) video=video1+video2+video3 video=audiodub(video,audio) return BicubicResize(video,360,240) -
Thanks, but I was able to figure it out on my own. First, the videoraw/video thing in line 19 was indeed a typo. I was using videoraw to test things, and forgot to change it back to video when I posted it.
The audio sync problem was a result of my computer not being able to make the YUY2 to RGB32 conversion on the fly. The problem occurred when I viewed the AVS script directly in Windows Media Player. After running a portion of the video through TMPGEnc, the sync was fine.
Thanks again for the help.
Mencoder and watermarks
By FlyerUA in forum Video ConversionReplies: 0Last Post: 6th Feb 2012, 17:50 -
erasing watermarks
By agent222 in forum Video ConversionReplies: 1Last Post: 6th Jan 2010, 12:42 -
removing watermarks from MP3 files
By UncleBose in forum AudioReplies: 2Last Post: 16th Dec 2007, 23:08 -
How Do you removelogos and watermarks from videos
By partymasterdave in forum EditingReplies: 6Last Post: 23rd Nov 2007, 12:11 -
Watermarks
By liddu in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2007, 23:45
