hi, my keyboard ports are broken for my desktop, ill sort them out later, is there a way to hook m,y laptop to my dektop to to use my lptop to control my desktop
also is there a caple/program i can use to take control of my desktop using my laptop,
Results 1 to 12 of 12
No... you can't connect your laptop keyboard to your desktop.
You can install VNC or use remote desktop (if you are running windows XP) to take control of your desktop from the laptop. You would, of course, have to install it (VNC) on both machines.
I personally use Kaboodle. It's a pretty easy setup and easy to use. -
hi, thanks for the great replies, i dont think i was banned, i dont think i have broken any rules except for a few mistakes, i dont mean anyone any harm
oh, in a message about my i,p showing i was in tehs tates when i am actually in the uk, the cobra moderator thought i was trying to be someone elss (dave i think?) so he banned my but then another moderator stepped in and explained it was common with aol users so i guess he unbanned me
I love my AOL.Originally Posted by goldenvirginia
Remote desktop should work. -
jimelanko, i really dont know, maybe cos when i did my initial computer setup i clicked the u.s.a, my keyboard is still set to u.s.a settings, that might be it, i really dont know, its never been an issue except when sky said i couldnt use their service cos my i.p said i was in the states
Nope, it's added automagically when you register...based on geoip from www.maxmind.com ... you can of course manually change it also...Originally Posted by jimmalenko
and this is not video related, moving to the computer forum section. -
The simple solution is to go get a USB keyoard ( $9.00 ).Originally Posted by goldenvirginia
keyboard help urgent
By dnmnbg in forum ComputerReplies: 2Last Post: 3rd Apr 2012, 22:45 -
Keyboard shortcuts for rm video?
By kathorama in forum Newbie / General discussionsReplies: 4Last Post: 16th Dec 2010, 18:12 -
Broken or not broken hard drive?
By romanstopme in forum ComputerReplies: 3Last Post: 17th Sep 2009, 13:04 -
Keyboard question
By didikai in forum Off topicReplies: 5Last Post: 3rd May 2009, 18:59 -
keyboard problem
By Seasonal in forum ComputerReplies: 5Last Post: 2nd Jul 2007, 15:41
