    Jun 2007
    Netherlands
    Since yesterday I am having problem with my keyboard (i.e PackardBell multimedia keyboard). The keys characters are misplaced.
    For example;
    The character @ not more with shift on key 2 but on key “ . So now if I need @ I press “ and if I need “ I press key 2 with shift. This is only one example, some other characters are also misplaced.
    I was looking to troubleshoot but not success yet. Please do help me here.
    Feb 2004
    Australia
    Most of those issues come from the crap software that comes with keyboards ... but knowing what it would be called on your pc , is up to you to locate ... Possibly its done a walk off , and just needs uninstalling , reboot , reinstall to cure .
    After this , its shut down the pc , remove the keyboard , turn it upside down and shake the crap out of it to allow debris to clear .
    Check pins on ps2 connection not bent .
    If usb type , after pc shutdown , remove all other usb devices , and only connect keyboard and mouse .
    Sometimes its caused by a another device that has malfunctioned , but with no apparent symptoms showing .
    Try again ... If not cured , replace .
    Your lucky its not caused by a barcode scanner ... Were back in bussiness once more ... After 2 full days of stress , caused by quicken upgrade that went south .
    Thankfully , thats what disc imaging is used for .
    May 2003
    Peterborough, England
    It sounds as though your pc is confused over what country keyboard layout you have. In your example, on a UK keyboard Shift+2 is " Go to Control Panel, Regional & Language Options, Languages, Details and set your country correctly.
    Jun 2007
    Netherlands
    Thank you very much, the problem is reslove, LOL. Yes Richard that was regional setting error. My bother was just playing with it. thanks
    BJS your instruction are very interesting as well, i will keep in my mind all those. Thanks for your time.
    May 2003
    Ah yes, country settings.
    Back in the days of DOS, the country and keyboard settings were lines in a file called autoexec.bat. We had software that we ran at work that used letter keys to instigate commands. The Q key was used to Quit out of the program. Changing the line in Autoexec.bat from keyb=uk to keyb=fr meant that the machine then thought it had a French AZERTY keyboard instead of a British QWERTY keyboard. Great fun watching someone trying to quit from the program by hitting the Q key only to see an A appear on their screen....
    Nov 2005
    Ozstraya
    Those were the days!
    We had a wanna be guru in our office. I took great delight in configuring the keyboard to a language that did not have a backslash as part of its standard character set and starting him up as many directories down the hole as I could possibly go. Find your way back from there, obewan. I gave the simple solution to the village idiot of the office who instructed said guru accordingly and then dispatched him back to his box!
