Results 1 to 12 of 12
    Jan 2006
    hi, my keyboard ports are broken for my desktop, ill sort them out later, is there a way to hook m,y laptop to my dektop to to use my lptop to control my desktop
    also is there a caple/program i can use to take control of my desktop using my laptop,
    Jul 2002
    Up in yo' bitch.
    No... you can't connect your laptop keyboard to your desktop.
    You can install VNC or use remote desktop (if you are running windows XP) to take control of your desktop from the laptop. You would, of course, have to install it (VNC) on both machines.
    I personally use Kaboodle. It's a pretty easy setup and easy to use.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    VNC, Remote Desktop (Win XP), PCAnywhere, GoToMyPC .... to name but a few ...
    BTW, weren't you banned ?
    If in doubt, Google it.
    Jan 2006
    hi, thanks for the great replies, i dont think i was banned, i dont think i have broken any rules except for a few mistakes, i dont mean anyone any harm
    Jan 2006
    oh, in a message about my i,p showing i was in tehs tates when i am actually in the uk, the cobra moderator thought i was trying to be someone elss (dave i think?) so he banned my but then another moderator stepped in and explained it was common with aol users so i guess he unbanned me
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Forgive the possibly stupid question, but why does your location in your profile say US ?
  7. Banned
    Feb 2005
    USA
    I love my AOL.
    Remote desktop should work.
    Jan 2006
    jimelanko, i really dont know, maybe cos when i did my initial computer setup i clicked the u.s.a, my keyboard is still set to u.s.a settings, that might be it, i really dont know, its never been an issue except when sky said i couldnt use their service cos my i.p said i was in the states
  9. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Dude, it's nothing to do with your keyboard or setting up of XP. It's all to do with your profile on this site. You must have physically typed in "United States" upon registration here
  10. I'm a MEGA Super Moderator Baldrick's Avatar
    Nope, it's added automagically when you register...based on geoip from www.maxmind.com ... you can of course manually change it also...
    and this is not video related, moving to the computer forum section.
  11. Originally Posted by goldenvirginia
    The simple solution is to go get a USB keyoard ( $9.00 ).
  12. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    a-ha !
    This would be one situation where automagically could be misleading, no ?
