I've been using Ritek 4X DVD-R's for several years now. Lately it seems no one is distributing them anymore. All I can find are the white top printable ones in the 4X speed. Everything else is the newer G05 8X stuff which don't work in my burner, I don't care for the faster media because I ONLY burn at 1X anyway.
Does anyone know who still carries the Ritek silver top 4X DVD-R's?
Results 1 to 22 of 22
Are you in the UK, you're profile or sig' don't let on?
Have you tried:
http://svp.co.uk/searchresults.php
(used to be http://www.blankdiscshop.co.uk/)
The Blank Disc Shop has loads of 4x Ritek.......James....hmmmm....nice..... -
Ritek was never a good disc. G04 production ended in 2004. Buy a new burner, they only cost like $40.
The above site is still selling the G04
DVDs are on the below link.
http://svp.co.uk/products-list.php?cid=115......James....hmmmm....nice..... -
Sorry, I am in the United States.
I have burned 4000 Riteks with a 99.9% success rate. They seem like a good disk to me. If they are unavaileble now then I'll be looking for a good substitute. Are all manufactures dropping the 4x media? I hope not.
Why buy a new burner when mine is great. Besides, I have a requirement to burn at 1x and most new burner software doesn't support 1x. The slowest they seem to burn is 4x. -
Ritek G04 media was always excellent for me on my Sony 510a burner.
I used to buy them from Meritline.com and they still carry them.
http://meritline.com/ritek-ridata-4x-dvd-r-media-discs.html -
Originally Posted by Rich86
I am now in a search for a quality silver top 4x DVD-R with good price. -
The silver top ritek 4x were exellent discs...I never had a problem with them. The Ridata/Ritek 8x is as high as I would go now on Ritek media....above 8x on Ritek have been pretty crappy to my burners.
The best silver top I buy now are Taiyo Yuden BUT...I haven't seen 4x for a while....mine are 8x. -
Originally Posted by John Millican
upgrade the firmware of the dvd drive you have,failing that,get a new burner as stated above.
LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
Originally Posted by Gen-An
I say a 1x burn speed is required for making perfect PS2 game backups. Anything faster can result in a coaster but not always. Even movie backups burned at speeds faster then 1x can cause intermittent freezes on a burned DVD. Burning at 1x has ALWAYS provided me with a very nice backup no matter what. I have always used Ritek 4x with great success.
Slow and stead wins the race. I can't see a need for fast burning really. You'd need a very fast PC to burn at 16x anyway and that still would be questionable. Still, maybe it is time to upgrade my burner to take advantage of the newer media coming out. -
I haven't had problems burning movies at 16x personally. Either way, you're probably going to need a new burner as you said. Keep in mind too that the faster media often don't burn as well at lower speeds, so if you decide on a 16x burner and get 16x discs, I wouldn't burn any slower than 8x. They don't seem to be tuned for CLV speeds (1x, 2, 2.4x, 4x, 6x).
It may be time for you to look into a new burner. I think I paid $40 for my oem Benq 1620 - and it is far better than my Sony drive ever was and will burn to most anything with consistently good results. -
How about Taiyo Yuden 4X-R's
http://supermediastore.com/taiyo-yuden-4x-dvd-r-media-silver-matte-spindles.html
All I use is Taiyo Yuden! -
The 4x Ritek gave me excellent burns. That was the sole reason I bought some 8x Ritek. But those were junks, the burns were ok, just that they became usable as time went by.
Now I exclusively use TY media. -
Originally Posted by lawnman
This is what they say:
Taiyo Yuden 4X DVD-R Media Shiny Silver in Tape Wrap
Ratings:
Product Code: DVD01X0238
Manufacturer: Taiyo Yuden - Made In Japan
Media ID: TYG01/TYG02/TYG03
Mfr part #: DVD-R47VAL600SK
Taiyo Yuden 4X DVD-R Media General Purpose Version 2.0 are for data and video and come on 100 disc Tape Wrap. These disc are compatible with DVD-R burners that use DVD-R media for general purpose Version 2.0. These DVD-R's are very high quality and reliable. more... -
Originally Posted by kyemeng
But to get back on track ... one factor I like about shiny DVD disks ... is the ability to write on them with a permanent marker and if I goof up ... I can wipe it off with an alcohol based liquid ... perfume ... colonge ... etc ... but some of these new disks have an opaque rough surface and wont wipe off very well .... those low cost TY disks ... work well -
Originally Posted by lacywest
How did the fluke good DVD-Rs from Ritek & Prodisc come about?
By Bix in forum MediaReplies: 3Last Post: 19th Aug 2008, 15:23 -
SVCD2DVD To buy or Not to buy?
By enjohn49 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 21st Mar 2008, 10:55 -
Office Depot brand dvd-r/ Ritek seconds?
By dnix71 in forum MediaReplies: 5Last Post: 31st May 2007, 19:15 -
Ritek set to mass produce rewritable BR & HD-DVD Discs
By akrako1 in forum Latest Video NewsReplies: 6Last Post: 24th May 2007, 09:24 -
Ritek Ridata DVD-R 4X G04 where or better?
By Illicious in forum MediaReplies: 8Last Post: 15th May 2007, 10:41
