Results 1 to 9 of 9
  1. Hi, Im at a loss where i cant find any ridata go4s dvd-r 4x (white top manually printable) nowhere.
    Now i have looked through the dvdmedia list here but cant really seem to find a reliable dvd-r 4x media for my projects.
    I have a fairly old sony dru 500a burner and before i made this post i just ran into some ritek go4 rotting rants that scared me to look at my 200 or so pile of ritek go4s.
    In the dvd media list i usually tend to go with the most popular and most commented to have the most compatible with my burner.
    I cant find them dvdrs and dunno if i want them now that ive read them few rants.
    I almost went with buying a stack of ritek go5s but i read a few times they are less reliable especially with a sony dru 500a.
    I have one disk left and dunno which media to get.
    Anyone have any experience with dvd-rs for a dru 500a? Preferably media that is suited for data, video and audio storage?
    Thanks in advance.
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Just buy some VERBATIM dvd media or upgrade and buy a new dvd burner which is very inexpensive these days at $30.00.
    Before you buy any more of that toe jam on a platter, you might want to read this thread https://forum.videohelp.com/topic329098.html
  4. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Stick with Verbatim 16x DVD-R discs. They usually come in a package that looks like this:
    You can often find the Verbatim 16x DVD-R discs on sale at either BEST BUY or OFFICE MAX. Even the regular price ain't all that bad though.
    The next choice is to buy Taiyo Yuden 8x DVD-R discs. These burn great at 4x speed although so do the Verbatim discs. You can buy Taiyo Yuden at RIMA.COM at a price point that is cheaper than the Verbatim discs when not on sale but not as cheap as when the Verbatim discs are on sale.
    Anyways those are the two best DVD-R discs and both will burn A-OK at 4x speed.
    However you might want to consider getting a new DVD burner. The new Pioneer is nice. You can get the retail version at BEST BUY or the OEM version from an on-line website such as newegg.com
    The retail version is the DVR-1810B (the B is sometimes left off) and goes for $64.99 at BEST BUY and if you bring your computer in and pay extra they will install it for you. That would be the only real reason to buy it there.
    Otherwise the OEM version is the DVR-112D and goes for $31.99 + shipping at newegg.com
    - John "FulciLives" Coleman
  5. Hmm. i see. I think im best off buying a new burner. Didnt want to since i paid so much for the sony dru but might as well.
    I think ill try thoes Verbatim disks then.
    Now for the burner i was looking at this one:
    http://www.upgradenation.com/NEC_DVD_-RW_ND-3520A_16x_Dual_layer/ND-3520A-KIT-BGU/part...id-566674.html
    Looks great, but under just $50 is hard to believe.
    BTW, thanks all for your help.
  6. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Why would you wanna buy from that website. FYI that website has older models of dvd burners. Go to NEWEGG.com to look for a new dvd burner. Here's a few links from there:
    PIONEER 112D, $31.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827129007
    LG H42N, $28.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827136108
    LITEON LH-20A1P-186, $30.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827106050
    LITEON LH-18A1P-186, 31.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827106043
  7. Member FulciLives's Avatar
    May 2003
    It is a bit amazing ... the price of current day DVD burners.
    My first DVD burner was the NEC ND-1300A and as I recall it cost me just over $200 US Dollars with the shipping.
    It was a great DVD burner though
    P.S.
    Currently I have a slightly newer model (though "old" model now) Pioneer DVD burner.
  8. Well im still shocked. Just $40 for a great burner and i wont dare say what i paid for my sony dru.
    Anyways i got me the reccomended Pioneer burner and will try out some Taiyo Yuden then some Verbatim disk.
    Figured its bout time to upgrade.
    Thank everyone for all your help.
    Jan 2006
    FYI check http://club.cdfreaks.com/showthread.php?t=217817 to find 2 sources for the Pioneer DVR-710 (DVR-111D) for just $25 after rebate or just $15 after rebate for Google checkout from second source at the link.
