Hi all
I have a footage 1 hour long which was setup as 25fps 1.067 pal 48000hz, using premiere pro 1.5. I did this as i reside in the UK. When I go into FILE>EXPORT>BURN TO DVD, i see in the bottom left hand corner that the file is a whopping 4.1GB and the DVD itself is the normal 4.38GB.
So here's my question, How do I downsize the file say to 2GB so i can fit 2hrs worth on the DVD, But the last thing i want to do is to lose quality either in sound or what you actually see?
Please can you explain in lamen terms as I am new to this premiere pro 1.5. I also have adobe encore 1.5. Can this software help at all?
Kind Regards Josel
There are two things you can change to reduce the amount of space required. The simplest is audio. LPCM is uncompressed audio and takes a large amountof space compared to Dolby Digital (AC3) or mpeg1-layer2 audio.
Video is a little more complex, but it all rests on the bitrate you use. Use a bitrate calculator to work out what bitrate suits your runtime. If your runtime is short (1 hour or less), use a Constant Bitrate when encoding, and just plug in the number your bitrate calculator suggested. If your runtime is longer than an hour, and you bitrate starts to get down around 7000 or lower, consider 2 pass Variable BitRate, where the number the bitrate calculator produced is used as the average. These numbers need to be applied when you encode to mpeg-2. You can read your manual to find out exactly where they go in Premiere Pro.Read my blog here.
Premiere Pro 1.5 has a quick DVD preview mode which burns a representation of the timeline without menu options. AKA a "daily".
The "Adobe Mpeg Encoder" is located under "Export Timeline". It gives wide encoding options to DVD MPeg2 but needs a separate DVD Authoring program to finish the DVD. Adobe's authoring program is Encore but others can be used.
"So here's my question, How do I downsize the file say to 2GB so i can fit 2hrs worth on the DVD, But the last thing i want to do is to lose quality either in sound or what you actually see? "
50% compression is going to have an affect on quality. What was the source file? Was it a camcorder tape?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
josel,
You have been constantly ignoring moderator requests not to double post. You are now being issued a two card (double warning) as a result of this disruptive behavior. Next time a ban is automatic.
/Moderator Offline
downsizing a mov on mac
By devdev in forum MacReplies: 1Last Post: 18th Apr 2012, 10:13 -
Downsizing from 1280x720 while maintaining 16:9 ratio
By pooksahib in forum Video ConversionReplies: 13Last Post: 22nd Dec 2010, 14:18 -
Resolution downsizing
By neroguy in forum Video ConversionReplies: 7Last Post: 17th Jul 2009, 21:58 -
The unmitigated ruler of downsizing algorithms?
By The.Yield in forum Video ConversionReplies: 5Last Post: 9th Nov 2007, 18:02 -
Guide for downsizing xvid files?
By bogart219 in forum Newbie / General discussionsReplies: 5Last Post: 11th Oct 2007, 05:35
