Results 1 to 13 of 13
    Feb 2006
    hi.i have a movie thats a vcd file. that has 2 folders. cd1, and cd2, with a cue and a bin file in each after i extracted the first file in each folder using winrar.each folder is about 847 mb.i the movie is split almost 42 minutes each file. i ended up with putting the first half of the movie on one cd(the first cue file) and the second cue file on another cd (the second half of the movie) using nero ultra edition i thought nero would join the files but it just seems to do one cue file at a time. is there a way to join the files. do i have to convert them and burn to a dvd.i thought i could just burn cue files directly to cd`s.or are they suppose to be on 2 cd`s.hope you could help.
    Oct 2005
    666th portal
    bin/cue files of that size are probably svcd. you can use isobuster to extract the mpegs and reauthor to dvd if you wish or just burn them to cd and watch on your standalone if it suports the format. either way the quality will be the same.
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Nero didn't join them because they are two different cd images (there are supposed to be 2).
    If you want them joined together, then you will have to join them and then burn to DVD. Nero won't do that on its own.
    Google is your Friend
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    ...and before you ask: you can't join bins. You have to extract the mpg out of the CD images (the bins). Then, if it's VCD images, it's just a matter of authoring them as DVD.
    /Mats
    Feb 2006
    Hi I'm pretty new to all this so please bare with me, I've downloaded a movie that has 2 folders CD 1 & CD 2 with a cue & bin file to each folder I've extracted the mpg from each bin file using isobuster but not sure how to move on to be able to burn to DVD any help would be appreciated.
    It's better to love than fight!!
    Feb 2006
    OK thank you now I've read and printed the guide and done what it said with isobuster and ended up with a videofile.mpg what is now the best way to burn that to a DVD
  7. Member steveryan's Avatar
    Jan 2003
    Manchester
    You may want to author the videofile.mpg, keep reading the above guide.
    He's a liar and a murderer, and I say that with all due respect.
    Feb 2006
    Thank you both for pointing me in the right direction everything is easy when you know how but quite difficult if you don't so once again thank you
    Feb 2006
    Hi like i said yesterday thank you for all your help since then I've managed to burn 3 movies doing it like it said in the guide but what i cant do is a movie that has two files CD1 & CD2, I've extracted the mpg out of the two bins and I've used TMPGEnc DVD Authour on the videofiles.mpg, But what i cant seem to do is get the two videofiles.mpg to join so that i can burn to DVD. Although I've READ & READ i still cant figure it out so please HELP!!!
  10. Member steveryan's Avatar
    Jan 2003
    Manchester
    Although i'm 99.9% that your movies are dodgy I am still willing to help you. Read the guides. Just like I did when I wanted to transfer VHS to DVD, I read the guides that people had taken the time to create.
  11. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    If you put them on the same track in TDA (add file) they will play one after the other. No need to "join" because authoring does that.
    Feb 2006
    Thank you thats all i wanted someone to explain to me in plain English, All though i appreciate the time spent writing the guides sometimes you can be reading the same thing over and over again with out getting any where so thats the time to ask for help and hopefully you will get it with out being told to keep reading.
