Results 1 to 9 of 9
Thread: Having trouble with .bin/.cue files
  1. #1
    Member
    Jul 2007
    Posts
    17
    Specifically referring a Thinkwell lecture series, if anyone's familiar. I have each disc in .bin/.cue format. I tried converting the .bin to an .iso, then mounting the .iso in MagicISO. I also tried directly burning the .bin to a cd, but in both cases I don't get any sound when attempting to run the program.
    I'd prefer not to burn anything, but just mount the image in a virtual drive program and run it from there. Don't know much about the .bin/.cue thing. Any help would be appreciated.
    aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    Posts
    10,842
    might be svcd format? in which case vcdeasy, alcohol120% or cdrwin are your best choices to burn them to cd with. select the cue file which tells the burner app what to do with the bin.
    Oct 2005
    666th portal
    Posts
    10,842
    to extract mpeg-2 file from bin use vcdeasy or isobuster.
    Mod Neophyte redwudz's Avatar
    USA
    Posts
    24,327
    You should be able to play a .bin file with VLC media player. It will also play most .iso video files. Bin/Cue files are most often used with VCD or SVCD formats. If your players don't work with the files from them, you may be missing a codec. You may be able to see which one by dropping the .bin into Gspot 2.70. But VLC uses it's own codecs, so it's not bothered by that.
    If you wanted to burn the files to disc, Nero or ImgBurn can do that. Just select the .cue file. The .bin file contains the data. The .cue file is the burning 'instructions.'
    Member
    Jul 2007
    Posts
    17
    Thanks for the replies. Still no luck, though.
    VLC won't play the .bins. These things are played with a proprietary player which opens up a table of contents, and from there you select a lecture to play.
    I tried ImgBurn, and it said .cue files "are not supported at this time".
    Tried burning with Alcohol 120% using the .cue file, and still no sound.
    Originally I tried buring to cd-rom with MagicISO, first using the .bin, then trying with the .cue, and neither one worked. I get video, but no audio. I have other products from these guys, and the player works fine for them. It's just I had them in .iso format from the beginning...haven't had to deal with this .bin/.cue stuff until now.
    USA
    Posts
    24,327
    Does Gspot tell you anything about them? Audio or video? They don't sound like a MPEG format.
    Banned
    Jun 2007
    UNREACHABLE
    Posts
    2,100
    Not yet tried DAEMON Tools
    Member
    Aug 2007
    Posts
    124
    Open that .bin with gspot as redwudz suggests, you'll get some useful info.
    Are you saying even the Thinkwell proprietary player plays both the Alcohol burned CD and/or the mounted .cue (virtual cd) with no sound?
    Open that virtual drive (mounted .cue) with windows explorer. Do you see files / folders?
    Banned
    Jun 2007
    UNREACHABLE
    Posts
    2,100
    Not all applications support every minor/possible variation in the
    .cue file format (for example, Prassi ONES does not understand
    the .cue sheets created by VCDImager) --- this the reason why
    I suggested Daemon Tools to the OP.
  1. cue and bin files
    By natty in forum Newbie / General discussions
    Last Post: 21st Jun 2011, 15:25
  2. extracting the bin/cue from .oo1,.002 etc files
    By belwas in forum Newbie / General discussions
    Last Post: 7th Jan 2010, 00:59
  3. Replies: 2
    Last Post: 24th Jul 2007, 09:11
  4. What files/settings do I need for bin/cue
    By Choppa in forum Authoring (VCD/SVCD)
    Last Post: 23rd Jun 2007, 21:29
  5. How to merge 2 cue/bin to one DVD
    By motleycool in forum Newbie / General discussions
    Last Post: 7th Jun 2007, 21:26
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
