I have this movie in a cue and bin format, I have mounted the bin file and it contains these folders is there a way to convert the movie to .avi if so what folder is movie in as it looks as if its in the MPEGAV folder, but its a .DAT file
Yes, you've mounted what we called a Video CD with motion video compressed with MPEG-1 standard (*mpg or *mpeg but MPEG-2 can have these extensions too). The motion video(s) is (are) in the "MPEGAV" directory as *dat file(s).
You must first extract the video as a valid MPEG-1 file. You can use VCDGear as aedipuss mentioned or with Isobuster : open directly the *bin or *cue file and "Extract but filter" option each file in the "MPEGAV" dir (AVSEQ01.dat, etc). You will get your MPEG-1 files.
You can convert your MPEG-1 files with Virtualdub, AviDemux to AVI.
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 00:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
