https://forum.videohelp.com/viewtopic.php?p=1457291#1457291
How about the devices for hooking all this up ... especially when a HD [with a hard drive] Cable box [Motoral 6412] is already connected ...
My television is the Sony 51" ... KP-51WS520 ... HD ready [not HD tuner inside]
My plans are ... Mount an antenna ... connect an amplifier and send out 3 feeds ... Bedroom ... living room and my computer room ...
What devices/equipment are available for ... switching purposes for switching between my Comcast HDTV and the cable from the Antenna.
Reason for doing all this ... Comcast provides a very lousy signal for the channnels below CH 66 ... CH 66 [HBO] and above are great but everything below is lousy. I do like the Sci-Fi CH [CH 64] and it too is terrible.
I watch Suface on Mondays ... Supernatural on Tuesdays and Smallville on Thursdays and the image is lousy with lines rolling from the bottom going up.
So this is why I'm investing in a HDTV outdoor antenna system.
Does anybody have a similar system ... already up and running ??
Anybody have any suggestions.
Good link for antenna placement >>> http://www.antennaweb.org/aw/welcome.aspx
I live in Hanford CA ... most of the stations are broadcast from the Fresno CA ...area .... My Zip code is ... 93230
The only stations broadcast OTA are your local channels. I would be very surprised to find someone broadcasting a cable channel (SciFi) OTA.
Google is your Friend -
I too would be surprisedOriginally Posted by Krispy Kritter
Is This The Right Cable To Connect My Pc To HDTV?
By superstar in forum DVB / IPTVReplies: 18Last Post: 10th May 2008, 19:53 -
HDTV: Cable or Dish?
By fritzi93 in forum DVB / IPTVReplies: 27Last Post: 13th Dec 2007, 00:26 -
PC to HDTV VGA Cable Issue
By wcndave in forum Newbie / General discussionsReplies: 2Last Post: 1st Dec 2007, 14:57 -
HDTV Cable Card from motorola
By lein in forum DVB / IPTVReplies: 4Last Post: 4th Oct 2007, 16:49 -
Standard cable on hdtv...
By bla4free in forum Newbie / General discussionsReplies: 6Last Post: 23rd Jun 2007, 23:35
