I saw Norton anti-virus quaranteend DVDfab decrypter as security risk. classified as winfixer.
http://securityresponse.symantec.com/avcenter/venc/data/winfixer.html
According to the description any software that prompts you to purchase now has winfixer? and would be removed!!
Results 1 to 30 of 37
more than likely a false positive,seeing as its the new definition update to norton that detects it.
another reason why symantec products arent the most reliable,itll be more than likely fixed soon.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
I was forced to remove norton several years back when it reported itself as a security risk.
A false report indeed but if it can report itself as being untrustworthy I must uninstall it.
Add me to the list of Norton haters. I used to love their product. It was a pain in the ass to remove too. Had to edit my registry! Currently I am using AVG Free and have been satisfied so far.
Darryl -
I saw the title thread and thought I'd not be too suprised if Norton detected itself as a security risk and **** me I'm right.Originally Posted by ROF
Brilliant.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
I wouldn't run a Symantec product on my PC if you paid me. The installed app's intrusion into your sytem (even if you do complete uninstalls) is legend.
Avoid all eye contact!! -
How about these articles?
New rootkit found in Symantec software:
http://arstechnica.com/news.ars/post/20060112-5960.html
Symantec rootkit:
http://blog.slaven.net.au/archives/2006/01/13/symantec-rootkit/
Symantec Closes Rootkit Hole:
http://www.enterpriseitplanet.com/security/news/article.php/3577181
Symantec denies it uses rootkit in software:
http://www.itnews.com.au/newsstory.aspx?CIaNID=21755 -
Virus checkers that run in the background cause a significant impact on computer performance as well. If you have a virus checker that runs in the background and have grown accustomed to your computer's performance, you will think you have a new faster computer if you uninstall it. Everyone has their own preference, but I prefer to follow four rules:
1. Don't click on email attachments unless you are SURE that it is legitimate. Simply recognizing the apparent sender isn't enough. One of the most common modes of virus' spreading is a virus that highjacks a computer and sends a copy of the virus by email to everyone in the address book on the highjacked computer.
2. Install Windows updates in a timely manner. The security updates block newly discovered exploits and vulnerabilities.
3. Do frequent virus scans with a non-resident virus scanner. There are a couple of good free ones - Trend Micro's House Calls and Panda virus scan.
Do frequent scans for spyware and other "malware" with scanners such as Adaware or Spybot Search and Destroy. A lot of the stuff that these tools remove can slow your system down because they run in the background.
System resident virus scanners can also cause a false sense of confidence. A number of virus’, Trojans and other malware knock out the virus scanner as a first order of business when they attack a computer. The system user meanwhile is fat, dumb and happy thinking that Mr. Norton or Mr. MacAfee are taking care of them – BUZZZ, WRONG! -
The rootkit is in Norton Systemworks....not necessarily Norton Antivirus. I've never had any false positives on my old computer and have always used Norton Antivirus since 2002.
I recently had to upgrade to Norton AV 2006 because my 2002 version was just too damn old.
I've run every version of DVDFabDecrypter since it came out....never a hit on that software either. -
well check it today,i just did,and its there ..the window popped up,norton has detected a blah blah......
on the newest version of dvdfabdecrypter,and it wasnt even installed yet..i just downloaded it and thought id check it.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
OK...now what?
Scanned my "downloads" folder where all of my past and
present DVDFabDecrypter .exe's are kept....nothing found.
Definitions are up to date as you can see. -
[sarcasm on] I guess you have nothing to worry about. Norton is very trustworthy. [/sarcasm off] :/Originally Posted by hech54
I gave up on Norton too. Their 2003-2005 versions are all bloated memory hogs and CPU hogs. I recently talked a friend into switching too, once he found out how good his computer ran without Norton. Switched to Outpost Pro Firewall and Avast Antivirus. Less bloat, daily SMALL kb updates, and a lot less CPU usage. And if these programs ever become memory/cpu hogs, I will switch yet again to something else.
Boot up time also significantly drops when all Norton products are removed.
Yea...my Evil crappy old Dell machine with Evil crappy
Norton Antivirus has such CPU usage problems...
Not to mention those false hits on Norton too.
theyve changed the version to download on there website,i see.Originally Posted by hech54
the newest one at release contained it,but soon after,it was changed,as i just redownloaded it again,and after checking it,its a different one-both versions taken off the site and not a mirror---who knows,maybe one of there mirrors or download locations were compromised.
pmsl..gotta admit though,DELL are shit,no offense,but cheap crappy parts and bad service,maketh not a great pc company,hmmm quite like most of pcworlds here in the uk too..heh.
I stopped using Norton AV when I purchased my sound card. Apparantly, it conflicted with the drivers from my Audigy 2 Platinum sound card and as a result, the auto-protect would never be enabled. Tried all fixes suggested by Norton, still no solution, so I switched. I use AVG and would never go back.
i started using avast on my lappy,and it works really well.
some constant updates,and good active scanning,small footprint too,as norton just killed my lappy straight off,and its not a shit one either.
put avast on,and it runs better,and doesnt run out of resources in 15 minutes.
i plan on stopping nortons support,when my current version of 2005 runs out,and switching,as now the other companies are getting better and better,leaving shitemantec out in the cold,for an ever expanding user base.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
You must mean DVDFab & not DVDFab Decrypter, because DVDFab Decrypter is free and does not prompt you to buy itOriginally Posted by INFRATOM
And i have never had a problem with any of the last 17-18 or so versions of DVDFab Decrypter or hits on it from norton & i run norton ISP 2004 & 2005 on 4 of my local machines.
And many friends use them also and i have never experianced or known anyone to have experianced any of this stuff being said
And my system resource meters look like hech54's. -
Just so you know, DVD Fab Decrypter can be set to do an automatic check for available updates when you load it. This is a selectable function in DVD Fab Decrypter. This may be a trigger with some virus checkers.
@Noahtuck
nope,it was dvdfabdecrypter all right, i downloaded it,it came up flagged by norton,downloaded it again,and that one was clear.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
@ RottenFoxBreath
I was actually refering to INFRATOM's comment,
Because it does not prompt for you to purchase.Originally Posted by INFRATOM
Even with the auto update i don't think it prompt's you, it just does it in the background.
But i don't know, it does not show any problem's here & never has....
@ SCDVD,
Oh yeah!! as soon as it loads for the first time, that's the first thing i always uncheck, as i do with any program, automatic updates!!
If i want something updated, i'll do it myself 8)
And i have yet to have my firewall not catch anything trying to connect and ask permission before allowing it to.... even during instalation. -
I was fool enough to install Norton Systemworks on my desktop a couple of years ago now. My analyses went from taking around 40 minutes to the best part of two hours. NS would not go away without dynamite (ie a complete reinstall of Windoze
), so I have not installed a singular Norton product since. To add insult to Norton's injury, I also have had my spyware and adware problems slashed by ninety percent since installing McAfee's viruscan and firewall products.
But that is beside the point. The point is that I did not pay for an Athlon XP 2800+ so Norton could make it run like an 850 MHz Duron.
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
At least McAfee doesn't slow you down and when it's uninstalled, it's uninstalled.
Thanks for all the info. on Norton in this thread. Last night, scanning, it picked up multiple "threats". Turned out to be DVDfabdecrypter.. Priceless!!.
Question about Norton Internet Security
By sohaibrazzaq in forum ComputerReplies: 3Last Post: 9th Oct 2010, 10:51 -
Norton Internet Security 2009 deleted StaxRip
By lacywest in forum ComputerReplies: 2Last Post: 17th Feb 2009, 23:03 -
DVDFab Decrypter
By HacktheHacker in forum DVD RippingReplies: 11Last Post: 25th Feb 2008, 23:10 -
DVDFab disables DEP = a security risk?!
By JohnnyBob in forum DVD RippingReplies: 3Last Post: 30th Dec 2007, 14:21 -
DVDFab HD Decrypter???
By bltprf in forum Newbie / General discussionsReplies: 11Last Post: 9th Jul 2007, 00:09
