Results 1 to 12 of 12
  1. When I go to the free page on the website the download icons disappear and I cannot download. I remeber someone posting about this a while ago but I didn't have any problems then. Anyone else having this problem? Any ideas why? I've checked pop up blocker, firewall etc.
    Oct 2005
    666th portal
    i was just there and the site is working fine. what browser are you using? does it allow javascript? if not turn it on.
  3. I use IE6 and javascript is allowed.
    Oct 2005
    666th portal
    firefox..... microsoft is going to force i.e.7 on you shortly anyway with a stealth update.(ok so it's a rumor, but ....)
  5. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    I was a part of the discussion in that post you are referring to and that poster having problems was also using internet explorer. I would also like to suggest you using firefox for your browser as well. You will no longer have those problems then. I only use ie for those few sites that just don't work with anything else. I think if you switch you'll like it.
    Here is the direct link if you absolutely don't want to switch browsers.
    http://www.dvdfab.com/mlink/download.php?g=HDDECRYPTER
    Donadagohvi (Cherokee for "Until we meet again")
  6. Thanks for the link Freebird73717, much appreciated. I'll give firefox a try.
    Jun 2005
    Vermont
    And a nice feature with Firefox is that it has a free ad-on called IE View that allows you to right click on any page and gives you the option to "View This Page in IE". Very Handy.
  8. Nothing wrong with IE,it must be your AV software or some other setting.
    Feb 2008
    I can't copy "saw IV" with DVD fab decrypter lates version. can someone help me?
  10. hans,last i checked DVD Fab Decrypter had the latest support for Saw 4. I copied it myself for my sister and it copied just fine. make sure you have the most recent version. they updated again a couple of days ago.
    Oct 2007
    Just to be sure, did you go to this page?:
    http://www.dvdfab.com/free.htm
    DVDFab Decrypter is now DVDFab HD Decrypter
  12. Works great for me. Nothing better than DVDFab.
