I work in the AV industry. I'm looking for an inexpensive way of recording several broadcast quality video feeds with audio to hard disk. A computer would work, but I'm not familiar with anyway of capturing up to 4 DV feeds at once.
Basically, we have 4 broadcast cameras, and we'll have a separate audio mixer for audio. We'd send some device either composite or component BNC and some audio, and we'd like to record that to hard disk, possibly as DV.
We could record a DVD for each feed with separate DVD Recorders, since they're really cheap now, but will hard disk ones overcome the 2 hour limit without sacrificing quality? Those DVD Recorders that have hard drives built in, will they allow recording for the max of the hard disk? And then you burn later?
If anyone know of any pro-sumer equipment, either PC or standalone, please let me know. Thanks!
Are we talking about DV or uncompressed 4:2:2 SDI (SMPTE-259M) or something else?
What model cameras?
"We'd send some device either composite or component BNC and some audio"
You mean analog? Be more specific.
Are you saying you want DV format on HDD?
What will be done with the recorded video?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Sorry, its analog video.. RBG/Sync (4-wire BNC) or Composite. They're high end Sony broadcast camera with CCU's.. Canon lenses. The signal leaves the camera over Triax to the CCUs.. The CCUs are capable of SDI output but unfortunately we don't have the cards in them to suport that... Analog is fine though.. .
We basically want to record each camera's feed. We normally use DVCPro decks but our decks are getting repaired.. and we're looking for other options as well.
We could record to DVD, but at SP mode, that's only 2 hours... which brings up the question about DVD Recorders having hard drives. -
How long must the capture be? Some DVD recorders allow 12-15 Mb/s MPeg2 to HDD but I think they are limited to ~9 Mb/s to DVD output.
You could record multiple DV format streams using 4 Canopus ADVC type devices but the computer may choke on 4 DV feeds without careful RAID design. Or use multiple computers.
You could go with multiple hardware PCI MPeg2 encoding cards of acceptable quality. Maybe a pro video dealer will rent you 4 Canopus or better.
http://www.canopus.com/products/mpegencoding.phpRecommends: Kiva.org - Loans that change lives.
Pity you said inexpensive, otherwise you could run each camera through an ADVC to one of these (need 4 in total) http://videoguys.com.au/scripts/prodView.asp?idproduct=423
Read my blog here.
Thanks for the info.
9 MB/s DVD Recording might be just fine to HD. I don't want a DVD Recorder without a hard drive as our material is sure to be longer than 2 hours... and I don't want to have to lower bitrate to fit it all on. If it can record to hard disk, for 3-4 hours, that would be plenty.
recording audio using the ati tv wonder pro
By cadams8221218 in forum Capturing and VCRReplies: 4Last Post: 22nd Mar 2009, 18:12 -
What HW/SW do I need to broadcast a semi pro TV show?
By sheikvid in forum Newbie / General discussionsReplies: 4Last Post: 29th Dec 2008, 10:09 -
Pay for semi-pro photographer?
By thecoalman in forum Off topicReplies: 7Last Post: 16th Sep 2008, 11:45 -
Is anybody having trouble burning semi-pro?
By mikes01 in forum DVD RippingReplies: 3Last Post: 12th Jun 2008, 19:18 -
Semi-Pro DVD back-up issues
By xoADAMox in forum Newbie / General discussionsReplies: 4Last Post: 6th Jun 2008, 08:15
