I started a new thread from this old thread:
https://forum.videohelp.com/viewtopic.php?t=225651
as the question is quite different from original and more current.
Sure you can do this, but it will likely require a few adaptors and if you're just looking to plug in an external mic, it may be overkill.Originally Posted by JeffD
I'm not familiar with the PV-GS65 camcorder, can you set the mic input level to be either "mic" or "line"? Reason for this is that "mic" input levels are very small, a fraction of the voltage that a "line" level is -- and the UB802 mixer is designed for line level output, as it's aimed at plugging directly into the line inputs on an amp.
BUT you can get an adaptor (attenuator) that'll reduce a line level signal to a mic level signal, they're not very expensive, a few dollars each. You'll need two attenuators, one for each output channel (L + R) on the mixer. Then just run whatever kind of cable you need to change the plugs on the outputs of the attenuator, to the jack on the camcorder, I'm guessing you'll just need a stereo RCA cable from the mixer attenutors to a 1/8" stereo plug for the mic in. Then you can fine tune the mic input setting on the camcorder by adjusting the level output of the mixer. START AT THE LOWEST VOLUMES ON ALL SETTINGS!!! Then very slowly turn things up until the sound is good.
Again, this may be overkill, because you could just as easily plug an XLR to 1/8" microphone adaptor cable from your mic to the camcorder, and voila, you've got an external mic!But yeah, I can definitely see there can be times when it's nice to be able to tweak the sound levels externally, the mixer will have much more fine control than (I'm guessing) the input on your camcorder. Plus this way you could even plug in additional mics to the mixer (even a wireless) and set all the levels on it, much easier than hassling with tiny buttons on the camcorder.
If there's something specific you're trying to do for a certain job, if you let us know we can probably give more specific feedback (pun intended).![]()
Ozy -
Thank you for your very comprehensive reply.
Good idea, and thanks.Originally Posted by ozymango
Yes.I'm not familiar with the PV-GS65 camcorder, can you set the mic input level to be either "mic" or "line"?
Yep; that's where my thinking was headed... Son Jake and I play music together when he graces us with his presence (acoustic folk/rock -- songs of MY generation that I'm thrilled he loves, too), and I thought this setup would allow me to record our performances from time to time -- better than the camcorder's internal mic would.Again, this may be overkill, because you could just as easily plug an XLR to 1/8" microphone adaptor cable from your mic to the camcorder, and voila, you've got an external mic!
Excellent. I'm sure I'll have more Qs once I get the equipment and start playing.If there's something specific you're trying to do for a certain job, if you let us know we can probably give more specific feedback (pun intended).
Thanks again,
JeffD -
Standard ways to hook up a balanced 600 ohm pro mic to a camcorder are.
1 Impedence matching transformer (Low to High Z Transformer)
http://www.shure.com/accessories/a85f.asp
http://www.nationalavsupply.com/Product.aspx?DeptID=2&ClassID=26&SubClassID=157&ProdID=677
2 Beachtek type adapter (clones exist)
http://www.beachtek.com/
3 External mixer with unbalanced mic level out like you are doing
Other audio stuff
https://forum.videohelp.com/viewtopic.php?t=268824
https://forum.videohelp.com/viewtopic.php?t=275537Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks, edDV. I'll come back and consult your post many times, I'm sure.
JeffD
Need Sugestions for Camcorder with mic input under $300
By techspark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 4th Apr 2012, 20:07 -
3-channel xlr mic mixer with 3.5 mm camcorder?
By hurry in forum AudioReplies: 1Last Post: 21st Sep 2011, 09:40 -
Need mic input on camcorder
By loldmanjenkins in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 11th Dec 2010, 17:00 -
Wireless Mic to Camcorder Help
By bowmah in forum Newbie / General discussionsReplies: 12Last Post: 23rd Sep 2008, 01:04 -
Need advice on getting a mic for my camcorder.
By OM2 in forum Newbie / General discussionsReplies: 3Last Post: 20th Apr 2008, 14:01
