I am looking for the cheapest-possible decent picture-quality HD camcorder with a microphone input, as sound quality is very important to me. Does anyone have any suggestions?
Results 1 to 13 of 13
Just checked latest HD - Toshiba X100, no mic input.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Sure...I suggest you read this whole site: www.camcorderinfo.com.
That one requirement is why I had to buy an expensive one.
years ago I actually had to mod my hi8 camera and installed a mic input. Do not know why a mic input is not more common on video cameras anymore (go back to the late 80's/ early 90s and it was common to find it)
http://www.kiva.org/about -
I have a q4 6600 and I will not use HD again until I get a new i7 that's for sure.
How much is your budget? If your production quality is important to you, capture audio externally. There are a number of flash recorders out there in a range of specs, capabilities, and costs from Sony, Zoom, m-audio etc. You can feed better external mics to these recorders, or the line outs of a mixing board, if such is being used and is available at the venue. You then drag the resulting audio file onto the appropriate track in your NLE and sync the lot.
You can't find really cheap HD camcorders with mic inputs. The possible exception is Canon, which has retained mic inputs as standard even on their SD models. But even if there are mic inputs, there is always the matter of stringing an appropriate mic into those 1/8in jacks as any reputable mic will always be XLR balanced. This means getting an adpater like Beachtek, which are not cheap. XLR-input mic jack camcorders will tend to be prosumer and professional and necessarily be $$$$$$.
In the end, the flash recorder trumped all else for me.For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
A used Canon HV20 is your best bet if on a budget.
You can adapt XLR mics with a Beachtek or Shure A96F transformer
http://store.shure.com/store/shure/en_US/pd/productID.104215400
External mic input isn't enough. You also need to be able to shut AGC off and control audio manually. The HV20 has that feature + peak meter + speaker (but alas no headphone jack).Recommends: Kiva.org - Loans that change lives.
the little canon hot shoe powered dm50 mic works well in most conditions for the hv20/30/40. i have used it extensively for concerts and vocal performances, and for the price it's great.
http://www.bhphotovideo.com/c/product/201377-REG/Canon_3176A002.html -
Full HD camcorder + MIC Input for recording Lectures
By AjnabiZ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 16th Apr 2016, 10:49 -
Need Sugestions for Camcorder with mic input under $300
By techspark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 4th Apr 2012, 20:07 -
By AjnabiZ in forum Capturing and VCRReplies: 0Last Post: 20th Feb 2011, 20:46 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 11:46 -
mic input on minidv
By supersam163 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 9th Jan 2008, 20:02
