I hope this is the right forum. I have nero now but hate their tech support at 1.29 a minute. Are there any other software programs out there that are as good? I just write mp3 and burn dvd movies.
thanks phaz
Results 1 to 13 of 13
Better watch out. This comes directly from the fearless leader.
https://forum.videohelp.com/viewtopic.php?t=289847&highlight= -
est, adj.
There is no best.
"Best" is a subjective term, normally based on opinion. That said, occasionally facts prove unequivocal best, but only very occasionally.
Do you mean "Best" as in "highest quality" ?
Perhaps "Best" as in "accept most source formats" ?
Maybe "Best" as in "easiest to use" ?
Or "Best" as in "fastest" ?
The best for you is the one that gives you the results you're trying to achieve. -
there is no source. it may exist elsewhere but the source is non-existent.
In that exact form, word for word ? Doesn't existOriginally Posted by offline
I added original material to a few snippets from a few posts put together (aka a collaboration) whereas you just Ctrl-C and Ctrl-V-ed your way into the "type it as if it were your own" school of plagiarism
... oh and next time you Copy and Paste, make sure you include the first character ("B")
If in doubt, Google it. -
Nero 7 - the ultimate audio, video, photo, data, and TV solution.
Source: My Nero 7 retail box.
@ ROF
As usual you are on the sauce and are 100% wrong. :P
@ Jim
On that convoluted logic, the mere duplication of a stop sign would constitute as plagiarism. Yet you admit you compiled this from other sources yourself. In addition, no Ctrl-C / Ctrl-V keys were employed. I merely referred to my photographic memory and typed out an edited version (removing the 'B'.) :P
Some of it from other sources. I actually did make up a couple of those sentences myself. So I used some documentation as reference, and then added my own words to it. A collaboration if you will.Originally Posted by offline
It's Ctrl-C for Copy and Ctrl-V for Paste. Ctrl-P would've printed it out for youOriginally Posted by offline
Time to bring back an old chestnut (those crazy frogs) for that ....Originally Posted by offline
To that I say:
burning software
By hardy in forum Newbie / General discussionsReplies: 8Last Post: 4th Sep 2011, 18:00 -
Best Burning Software
By bmoreravyns in forum Authoring (DVD)Replies: 32Last Post: 14th Oct 2008, 20:46 -
Best burning software???
By Eternal7331 in forum DVD RippingReplies: 8Last Post: 11th Oct 2007, 00:29 -
what burning software?
By dickdb in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Oct 2007, 17:48 -
burning software
By Cmonteith in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 19:07
