    Jul 2005
    illinois
    After the encoding, what software do you suggest to use to burn the TS_Video to a DVD?
    I have Nero Ultra 6, but it says it has compatibility issues with XP Home. Any suggestions?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    S2D will burn automatically when you have ImgBurn installed and have instructed S2D to do so. Also if you have a VIDEO_TS folder to burn then you can use the following to drive ImgBurn:
    See the bottom of www.svcd2dvd.com
    Jul 2005
    illinois
    Thanks for the info. Just downloaded ImgBurn and will check it out tonite.
