Results 1 to 9 of 9
    Jan 2001
    For burning software, is ImgBurn still the most preferred? I know the new Roxio is pretty good now for burning.
    Apr 2004
    Miskatonic U
    Imgburn is still the best. Roxio is bloatware.
    Read my blog here.
  3. Speaking of ImgBurn... I believe at one time it installed some kind of toolbar (or adware?) during installation. Does anyone know if it still does this?
  4. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    It may ask you during the install, you can decline and just get the program.
  5. Thanks for the info.
    Jan 2001
    ImgBurn use to let me burn a DVD even if it was over the limit of space. Now it gives me an error. I have a DVD that's 4.7GB, which is a little over. Usually it would still burn but you might cut off the ending which is usually just the credits anyway. Now it gives an error once the copy finishes and it wont play in my player.
  7. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Originally Posted by ally68 View Post
    imgburn use to let me burn a dvd even if it was over the limit of space. Now it gives me an error. I have a dvd that's 4.7gb, which is a little over. Usually it would still burn but you might cut off the ending which is usually just the credits anyway. Now it gives an error once the copy finishes and it wont play in my player.
    wrong
    Jan 2001
    Really? If the specs were close enough to the DVD file size, even if it was a little over. ImgBurn would still burn the disc. The disc will still play in my older DVD/VHS combo player for some reason, but not the new blu-ray player once I get the error.
  9. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    I know Nero used to allow for overburning on some formats, but of course this is a risky proposition and overburned discs don't play in all players. I don't recall Imgburn allowing, however because I work to spec, rather than penny pinching, it isn't something I would have tried or used anyway.
    Read my blog here.
