I need to convert some xvid video files into dvd fomat. Can anyone recommend some good software for doing this?
How much time do you want to spend learning how to do it ?
If it is a quick one-off, the free version of DivxtoDVD will do as good a job as any one-click-wonder, and a lot more reliably than most.
If you want to learn how to do this to get the best possible quality you can (note : this is heavily dependent on the quality of the source - which generally isn't as good as you think it is), then you will need to learn a variety of programs. This is as good a place to start as any http://members.dodo.com.au/~jimmalenko/AVI2DVD.htmRead my blog here.
Divx to Dvd is great software for what you are trying to do. Especially if you ant to fit more than 1 movie on a dvd. Another option is, The FilmMachine which, while slower than Divx To Dvd, allows you to use standalone encoders like Canopus Procoder or CCE. Either option is a good choice.
Converting Xvid AVI to DVD
By rocks911 in forum Video ConversionReplies: 2Last Post: 21st Aug 2011, 19:24 -
xvid to dvd converting help
By victoriabears in forum Video ConversionReplies: 12Last Post: 15th Nov 2010, 20:00 -
Converting .Xvid to DVD.... Please
By Galosat in forum Authoring (DVD)Replies: 2Last Post: 18th Sep 2007, 15:10 -
Converting from DVD to XVID
By morphjk in forum DVD RippingReplies: 11Last Post: 23rd Jul 2007, 16:33 -
Converting DVD to Xvid with a watermark?
By RushMaster in forum DVD RippingReplies: 1Last Post: 18th Jun 2007, 00:31
