File Size: 607,664,372 Bytes
Video Codec: XVID
Video Bitrate: 1504 kb/s
Audio Codec: 0x0055 MPEG-1 Layer 3
Audio Bitrate: 128 kb/s
Audio Bitrate Type: CBR
Duration: 49:20.943
frame Count: 88736
frames Per Second: 29.969
Display Aspect Ratio: 1.469
frame Width: 702
frame Height: 478
is the file information on one example of a whole, series I am trying to convert to conventional dvd (pal) for a dear friend who cannot play xvid files.
The result using TMPG is very jerky, good quality but jerky, is it anything to do with the bit rate which is high for an xvid file.
many thanks
Results 1 to 13 of 13
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
tried avs to dvd, it created similiarilly awful playing quality , am using windows 7 and with cuda enabled in tmpg, could that be why?
and avi2dvd failed to encode
I would try to play them on a dvd player then onto a dvd recorder but the dvd player says will not play the resolution, the one I tried though was 800 x 500Last edited by victoriabears; 15th Nov 2010 at 11:40.
Why are you converting from NTSC Divx (well, "NTSC" for lack of a better term) to PAL DVD? People in PAL land almost always can play NTSC DVDs fine. Making an NTSC DVD should fix the jerkiness problem. NTSC<->PAL conversions often cause the problem you see.
You have a very good point--the good friend in question has a dvd player from the first generation in the UK and , yes it may not play NTSC DVD's I will find out.
I have not had much trouble converting pal <> to ntsc when the source is a DVD but this is the first time I have tried 29.97 fps to 25 fps xvid.
I appreciate all the help.Last edited by victoriabears; 15th Nov 2010 at 12:47.
Probably not, I have also realised that I created a PAL DVD from the xvids, then played them back on a Philips dvd player which converted it back to NTSC for playback, !!! , a factor may be.
I am trying the "ntsc" xvid to NTSC DVD idea, see if that fixes itPAL/NTSC problem solver.
try the old DivxtoDvd...it's now ConvertXtoDvd but it worked fine back in the day. This version is the old free version...nice and simple
sorry the logs have gone with all my farting about,,or may be I did not set the option to save?
Are all those 30 frames per second unique? Or do you notice dupes? If they are unique you may be stuck with what you got and that will probably be the best you can do for a PAL DVD.
It would appear making a NTSC DVD is the answer it is much better, just gotta wait and see if the friends dvd player will play them
Converting Xvid AVI to DVD
By rocks911 in forum Video ConversionReplies: 2Last Post: 21st Aug 2011, 19:24 -
Help converting a Xvid to DVD with TMPGEnc 4.0 XPress
By ozzhead42 in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2007, 14:01 -
Converting .Xvid to DVD.... Please
By Galosat in forum Authoring (DVD)Replies: 2Last Post: 18th Sep 2007, 15:10 -
Converting from DVD to XVID
By morphjk in forum DVD RippingReplies: 11Last Post: 23rd Jul 2007, 16:33 -
Converting DVD to Xvid with a watermark?
By RushMaster in forum DVD RippingReplies: 1Last Post: 18th Jun 2007, 00:31
