I am wanting to copy some of my DVDs to XVID and store them on my HTPC so that I don't have to get them out everytime I want to watch them so I am wondering what is the best program to use so that I get the best quality without ending up with a huge file.
I have tried DVD Decrypter and then used TMPGEnc Express 4 to convert with good quality but have hit a snag with 2 DVDs that TMPGEnc wouldn't let me bring in all the .VOB files so I couldn't end up converting it.
I have tried Fairuse Wizard but have found it lacking quality. I am currently trying out AutoGK but is this really as good as people say it is or is there better?
So my question is what is the best way for me to go?
Results 1 to 12 of 12
I faced a similar choice last year when I ripped my entire DVD collection to my HTPC. I would suggest you use H.246 rather than DivX. It allows even lower bitrates while retaining the full DVD resolution. Lower bitrates means smaller file sizes. It performs better in regards to quality and detail retained.
MEGUI is a good place to start for H.246.
If you decide to stick with DivX then AutoGK is an excellent option which works well for general encoding purposes.Impossible to see the future is. The Dark Side clouds everything... -
Okay where do I find out more about this H.246 as I've never heard of it before?Originally Posted by DJRumpy
MEGui is all you need to encode the files. To play them back, you can grab FFDShow (http://sourceforge.net/projects/ffdshow) to handle the codecs.
I would suggest you use Media Player Classic for playback.Impossible to see the future is. The Dark Side clouds everything... -
I've checked out KMPlayer. It reminds me a lot of Zoom Player for it's option set. Initial impressions are good. It's a wee bit buggy, but certainly usable. I think I'll give it a go for a while to see if I like it.
I didn't think the options were overwhelming at all.Impossible to see the future is. The Dark Side clouds everything... -
Fair use wizard doesnt lack in quality.. as long as you use the quality setting at maximum and also give it a decent bitrate eg 1200-1700mb per film. My only gripe is that its a bit slow and its tricky to keep the ac3 sound
AutoGK works very well for me, but there are a couple of settings in the 'hidden settings' screen that really help (CTRL-F9). Personally I try to use the 1/3 DVD size option for movies. TV episodes I can go for the 700mb size. the quality is great especially from ripped DVDs. If converting from MPEG-2 files you may experience a few minor blemishes, but nothing to cry over. I use Xvid instead of DivX and am quite happy. Hey I'm only this planet for so many years so just how great does the end result have to be?
Relayerman
Converting Xvid AVI to DVD
By rocks911 in forum Video ConversionReplies: 2Last Post: 21st Aug 2011, 19:24 -
xvid to dvd converting help
By victoriabears in forum Video ConversionReplies: 12Last Post: 15th Nov 2010, 20:00 -
Help converting a Xvid to DVD with TMPGEnc 4.0 XPress
By ozzhead42 in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2007, 14:01 -
Converting .Xvid to DVD.... Please
By Galosat in forum Authoring (DVD)Replies: 2Last Post: 18th Sep 2007, 15:10 -
Converting DVD to Xvid with a watermark?
By RushMaster in forum DVD RippingReplies: 1Last Post: 18th Jun 2007, 00:31
