hello all,
i have Sanyo dvd player (7220DX) which can read Divx's movies.
i bought TEAC dvd and burn some...but the movie was jumpimg.
i took it to my friend and the movie wasnt seen at all.
so i suggest that the media is the problem so i bought Silver line DVD.
i burn some divx movies and now i have got a message "NO DISK".
As i put it in my friend's Dvd the movie was OK.
just to mention the dvd is new and i dont have problems to see original movie or other format.
can u give me any idea what to do..?
This is about a different player but much of the information will apply:
http://groups.google.com/group/alt.video.dvdr/msg/2ceddfcef68cc358?dmode=source&hl=en -
The jumping is most likely caused by the Divx files not being in a fully supported format for your player.
The "No Disk" message is either bad or incompatible media.Google is your Friend -
The "no disk" error is probably an open session disk. Most set-top Divx/DVD players don't like multisession disks or disks that haven't been finalized.
How can I show subtitles on the the top line and on the bottom line.
By Dracko in forum Authoring (DVD)Replies: 14Last Post: 8th May 2014, 15:03 -
VOB2MPG command line problem
By Toreadore in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 28th Mar 2010, 14:58 -
Taiyo Yuden Silver Thermal Lacquer 52X CD-R Media (Value Line)
By mccoady in forum MediaReplies: 14Last Post: 15th Sep 2009, 12:50 -
Subtitle Line Up problem
By ihmcjacky in forum SubtitleReplies: 3Last Post: 1st Jun 2009, 07:23 -
i bought 3 movies on line but they don't download they play from on-line
By N8DOGB4000 in forum Video Streaming DownloadingReplies: 6Last Post: 10th May 2008, 17:20
