    Dec 2007
    Hong Kong
    Some of the subtitles are too long to display and I try to use
    subtitle workshop to divide the lines according to the pre-set
    character numbers (say 20 characters) but it seems that
    subtitle workshop does not work as I expect, some of the
    long subtitles haven't divide even I have use "set maximum
    line length" option, is there any solutions for this?
    Thanks for you guys' attentions
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    To make it reflow the lines, select the subtitles (or all of them, with ctrl-A) and do
    Edit/Text/Smart line adjust
    20 characters seems very short. Standard is about 40.
    Dec 2007
    Hong Kong
    thanks for your reply~I have tried smart line adjust before and it has any other problem, you can see in the above figures.
  4. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    I wouldn't really trust it to break Chinese properly.
    Breaking alphabetic languages it will insert a line break in a space between words, but I don't think you have any in your text.
    They have a forum at http://www.urusoft.net/forum/
    I suggest you log on there and ask.
