Results 1 to 9 of 9
    Feb 2010
    Oslo, Norway
    I just discovered VOB2MPG, and find it most useful. Bought the Pro version right away to get hold of the command line functionality. I managed to build a DOS BATch file something like this:
    start "Myfile" "C:\Program Files\VOB2MPG\vob2mpg.exe" /v="U:\VIDEO_TS\VIDEO_TS.IFO" /o="I:\MPG_fra_VOB\01.MPG" /MainTitle
    This works great, and creates a Mpeg-file with the name "01.MPG". But when I add the /sc option to have the resulting file split into chapters, it seems like the "01" name is replaced by the program with "Title_01.. + the chapter numbers .
    I would very much like the ID I provide, to become the name of the file, just the way it does without the /sc option. Any ideas anybody?
    Toreadore
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Well as you have used the /sc option (seperate chapters), each file has to be unique. Hence the Title_xx_ch_xx naming convention. Can you indicate what you are expecting and i will add it in the next build if possible.
    Feb 2010
    Oslo, Norway
    Thanks for your reply, ChrissyBoy. What I expect is that the file name I provide with the /o parameter is used as a prefix for naming the chapters, e.g "01_ch_01.mpg", 01_ch_02.mpg", etc. The reason I want this, is that when I read up to 5 DVD's concurrently (yes, running 5 instances of VOB2MPG, starting all of them from a batch file), the resulting files will overwrite each other when i use the /cp parameter. That's why I provide unique /o name for each DVD i read. With the /sc option I loose the filename .. Another issue I ran into is that the resulting file name sometimes ends up as something like "...raw.mpg" I suspect that this is a temporary name which should have been renamed in the end of the process. Any ideas?
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    right you are.... i will add this in the next day or two
    Feb 2010
    Oslo, Norway
    Sounds like muuuusic" Thanks ChrissyBoy!
    Toreadore
    Feb 2010
    Oslo, Norway
    Any progress in this case, ChrissyBoy?
  7. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Yes. Can you drop me an email & i will send you a build to try.
    Feb 2010
    Oslo, Norway
    Hi Chrissy Boy - did you get my email about this?
  9. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    No Can you resend please?
